Results 1 to 9 of 9
Thread: Polks
    Nov 2009
    Default Polks
    I am looking at picking up Berg's Polk MM651's but my concern is that I am currently running the rear speakers in parallel showing the amp a 2ohm load and the fronts by themselves at 4 ohm. It is a kicker 700.5 amp. The problem is that they are 2.7 ohms, would i have to run the rears in series off of the rear channels to get the appropriate ohm rating??
    Thanks,
    Mark
    -Mark
    "Hey you only live once"
    Des Moines, IA
    What speakers would you have in the bow?
    Nov 2009
    Right now it is a set of DB651's I would run them off of the deck but I eliminated it and I run everything through an ipod and clarion eq
    -Mark
    Call me crazy for "talking you out of the sale" but I'm afraid you're going to be underpowered for these speakers running on the Kicker 700.5, especially if you go in series to a 4.7ohm load, if that's possible.
    That amp is rated at 70watts at 4ohm, 85 watts at 2 ohm. These speakers want 100watts RMS each... You 'may' be clipping the amp when you crank it up.
    ERR- scratch that calculation. 5.4ohm load??
    Nov 2009
    Ok at this point PHIL!!! what is you take?
    -Mark
    Dec 2006
    Tigard, Oregon
    Two 2.7 ohm speakers wired in series presents a 5.4 ohm load to the amp. If the 700.5 is rated 70W at 4 ohm, then its going to deliver a calculated 52W at 5.4 ohm, then divide that by two since there are two speakers being driven for a total of 26W per speaker which is obviously not going to get you the volume you want.
    You can't wire them in parallel because that would result in a 1.35 ohm load and the 700.5 can't handle that. So to do this right, you would have to drive the 4 MM651's off the 4 full range channels of the 700.5, then buy a separate two channel amp for the bow speakers.
    Al
    Al
    Default Price Drop - $120 and I'll split shipping.
    I'll give a little more to get these sold-
    https://forum.moomba.com/showthread....002#post133002
    Nov 2009
    I'll take them Berg for that price. I'll put them in my truck if nothing else.
    -Mark
    Nov 2009
    Stillwater, Oklahoma
    Thanks,
    Mark
    One of the MM651's per channel would work quite well with the amp. Two in parallel as mentions is going to give you a 1.35-ohm load, too low. Two in series will result in a 5.4 ohm load as already posted. It will run fine at 5.4, but will not have the power that the speakers can handle. It still would get fairly loud, but you will run ot of headroom before the speakers want to quit.
    Those speakers just want a biger amp, so understand it is not the fault of the Kicker amp...
    Phil
    Kicker
