Results 11 to 20 of 41
Thread: Pulling the Prop
04-12-2011, 12:33 PM #11
Does putting heat on it change the finish color of the prop at all?
04-12-2011, 12:46 PM #12
04-12-2011, 06:34 PM #13
If yoow pwop bee instawed on hot day and yuuu take off on a kooold day it be way hawder......Confusious 1632
09 21v LAUNCH
99 Outback LS. Sold
Doug
04-12-2011, 06:44 PM #14
Ok, buddy with the torch fell through unless I find one at Home Depot. Any other bright ideas? Do I HAVE to have heat?
Skate: LF Faction 44
Surf: LF Custom Quad & XXX
Tow Rig:
04-12-2011, 06:49 PM #15
go get yourself a $15 propane torch, last time I needed the prop puller plus a torch ,that sucka was on so tight
09 21v LAUNCH
99 Outback LS. Sold
Doug
04-12-2011, 06:50 PM #16
No, but Home Depot does...Hair dryer??
Tow Rig:
04-12-2011, 06:52 PM #17
forget the hair dryer or heat gun, get a torch, go big or go home
09 21v LAUNCH
99 Outback LS. Sold
Doug
04-12-2011, 06:52 PM #18
No, you could luck out, as I did, take the nut off and be able to pull the prop off by hand. For me, the prop had been removed at least once by the prior owner, because he said that he had replaced it.
You should be able to find a small propane or butane torch in the plumbing section of home deport (or similar store). Should work for your task.
Take the nut of and see what happens. Maybe a few light taps with a hammer. It the case of your prop, what are you going to do, damage it?2003 Outback, Assault EFI, (6) Polk Audio DB651s, JL Audio M6600 amp, JL Audio M1700 amp, JL Audio 10w6v2 subwoofer
04-12-2011, 07:22 PM #19
Harbor Freight has heat guns for $12. That was a purchase I thought id only use once but turns out I use it often!
2016 Moomba Mojo
2006 Supra 24SSV - Traded
04-13-2011, 08:00 AM #20
yes you need heat if your going to try to pull the prop this route vs. using a prop puller or some other method. you need to be able to heat the material in order for it to expand, hence why its so easy to take the prop off this route. seriously you can just about find a small torch anywhere... gas stations, walmart, hell the pharmacy might have them! git'r'done!
2004 Moomba LSV Blue
