Results 1 to 10 of 14
Thread: Help on Heater Install
04-11-2011, 09:06 PM #1Senior Member
- Mar 2007
- Clarkston, MI
- 146
Does any one have a heater on a 06 and above and could take a pic of were your line screws into the manifold/ eng to bring the hot water to the heater core.
Thanks guysMatt Glenn
04-11-2011, 09:22 PM #2
I don't know what that means or looks like, but you are welcome to come check out my boat in Royal Oak.
2013 Outback V
04-11-2011, 09:35 PM #3
Matt did you check out al's thread it's pretty detailed. If you bought the wye fitting then the intake is slightly different.
https://forum.moomba.com/showthread....Heater+installA Day at the Lake...Priceless
04-11-2011, 09:48 PM #4
i second that al's was so informative...my 08 was slightly different though. on the head of my engine i had what i believe is my water temp senor with small wire and connector that snaps on the sensor so i pulled the fitting screw out the sensor then instead of using and 90 degree elbow i used a street t so i could put the sensor and wire on top of t and the side i came out with my other fittings and valves. if this doesn't help out you i'll try to snap some pics and load em up on here tomorrow evening
08 lsv all red- dual battery system, kicker 700.5 and 450.2 amp, 10" kicker sub, wetsounds eq, polk db651 cabin speakers, exile xm7 tower speakers, ss thru hull fittings, seadek pad, evolutions cover
https://forum.moomba.com/showthread.php?t=10664
04-11-2011, 10:12 PM #5Senior Member
- Mar 2007
- Clarkston, MI
- 146
thanks
If any one has some pic's . Yes I have the Y , but that is for the return water to eng. I'm looking at were to pipe in to get the water. all the pics on the forum of a v drive I have a outback 06 which has a different set up.
Ian so you have heater that can with it?Matt Glenn
04-11-2011, 10:29 PM #6
Sorry did not realize you had a dd...
04-11-2011, 10:39 PM #72007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
04-12-2011, 07:54 AM #8Senior Member
- Mar 2007
- Clarkston, MI
- 146
Pics
Thanks bro, If you could take a shot of front of eng. were the line ties in that goes to the heater. If you don't know take one above eng and one side view on drivers side it should be there. Can you also take a pic of heater unit and were they pull the lines out of the floor to attach to them. One last thing if you have heater moomba switch can you see the pattern of colors that plug in to the back. Thanks for all the help
Matt Glenn
04-13-2011, 10:28 PM #9
Matt - Two sets of pics. First, the switch control for off, low, medium, and high fan speed. Also a pic of the heater box which is located up under the front dash. And, because I can't get more than five pics on a post, the engine. Next......
2012 RAM Crew Cab
Stuart
04-13-2011, 10:35 PM #10
...water lines to and from the heater core, which sits up under the dash behind carpet. One line connects to the driver side of the engine block. Line pumping hot water to the heater core? The other line connects to the water pump. The return? I can't get a picture of the heater box itself or where the lines to/from the engine connect to the heater core. Just not accessible. The last pic is a close up of the passenger side of the engine.
I will leave the motor box off for tomorrow in the event you need a follow up pic of anything. Hope this helps.Last edited by deerfield; 04-13-2011 at 10:38 PM.
2012 RAM Crew Cab
Stuart
