Results 1 to 8 of 8
    Default Use of Ethonal in Indmar Engines
    Looking over information from Indmar on the web, I see they will allow 10 percent ethonal in fuel, however the Moomba owners manual states not to ever use ethanol. Anyone have any good info as to why ethanol is not to be used per Moomba and Indmar is advising that it can be used?? I can only guess it has something to do with the fuel lines or tank.
    Sep 2006
    Default Replying to Topic 'Use of Ethonal in Indmar Engines'
    Good Question you have stumped the mkt guru not hard to do. Give me some time to figure it out for sure. I know in some areas all the fuel is blended. In general just use the lowest percentage of ethanol you can find. I will have an answer. Jay Warren
    Jul 2003
    This probably isn't the right reason, but.... I ride sportbikes and everyone says never to run ethanol in them either. The reason I recall hearing is that it will make them run hotter.
    Mar 2003
    s.e. washington state
    Went to Iowa recently and their making a state law that requires all fuels sold in the state to be at least 10% ethanol. So for some, you better get used to it.
    1998 Mobius
    310 HP PCM
    Jan 2005
    Has this question been resolved yet??? Were I am from in North Dakota, in a new effort to make people start using ethanol, they have made the 89 octane with 10% ethanol cheaper then the 87 w/o ethanol. I did a topic search and found this old post, but no answer to Will Watters question. It would save me a lot of green at the pump, so if anyone knows yet, please fill me in. Thanks
    Mar 2003
    I'd go with the engine manufactorers recommendation. In this case 10% ethanol is OK. But then I ran 87 octane in my carburated PCM last year and had no problems where they recommend 89 octane.
    1998 Mobius
    310 HP PCM
    Aug 2004
    Lake Hickory, North Carolina
    You must be careful, though. Using other than recommended may affect your warranty. However, if your warranty is expired, it prolly isn't a concern.
    I guess I am out of luck in CT. All gas has ethanol. According to my dealer I don't need to worry aobut it though. I hope that means that he will back me on any warranty issues due to ethanol.
  1. 350 Indmar
    By steveokanevo in forum General Chat
    Last Post: 07-02-2007, 03:22 PM
  2. synthetic oil for Indmar engines?
    By in forum General Chat
    Last Post: 06-11-2006, 11:42 PM
  3. Any New engines for 06'?
    By brianw21 in forum Sales & Information
    Last Post: 09-13-2005, 10:29 AM
  4. Replies: 1
    Last Post: 02-22-2005, 02:55 PM
  5. Indmar Engines
    By Kent and Carol in forum Sales & Information
    Last Post: 01-18-2004, 02:53 PM
