Results 1 to 9 of 9
Thread: Stereo Upgrade
    Apr 2007
    Las Vegas, Nevada
    Default Stereo Upgrade
    Well having a few great years with my current set up, I think that I want to upgrade my stereo system. I am talking a whole entire makeover. There is nothing wrong with my system, I just feel the need to upgrade. I am thinking of getting these "Bullet 650HPCOAX 6.5" Coax Speaker from Earmark Audio. I have not decided on the Amps yet. The only two things that I will keep are the Kenwood Head Unit and the Boston Acoustic G3 10" sub. I will need a total of 10 speakers. I just wonder if these will fit or match up with the holes that I have with the LED rings that I bought from Earmark. I guess I need to call them up to see if they fit. That might be the deal breaker for me. Not sure how much I want to spend yet.
    Aug 2009
    Montana
    figure out how much you want to spend..........then multiply that by 1.5 or 2 and that is what you will end up dumping into a new setup That's pretty much how I roll
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Lake Point UT....
    Pretty much spot on. All the little things will add up...
    Keep us posted..
    Arkansas
    Call David up. I'm sure he can help you out.
    I am running my Bullet coaxials with the JL G4500 because I couldn't justify the extra $100 in stepping up to the JL 6 channel for just a few more watts. I'm using a pair of JL G1300s to push the 4 tower speakers. The amp setups came recommendations of David and endless amounts of research.
    I love the look of the Bullets. Not sure exactly what you are talking about on the led light rings but i can tell you the Bullets are a little larger than the Polk DB651s I previously ran. The Bullets are tight but they do fit.
    Are you thinking HLCD or Coaxial on the tower? I went with Krypt on the tower due to price, size, and they are a good cosmetic match to the Bullets.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Apr 2007
    Las Vegas, Nevada
    They are the coaxial speakers. I already have cans for the tower. I just need to replace the speakers. I just might start there and work my way to the cabin. 4 new tower speakers, and a new amp. In regards to the light rings, I had earmark make me some for the MB Quartz that I have. I was just wondering if they will fit on the Bullet 650's? I will call on Monday to get a full price. Still not sure if I want to go with a 6 channel or a 700.5 channel amp. Currently I have a Kicker 700.5 amp that runs the cabin and the sub. The two rear cabin speakers are ran in series. I am not sure if I want to keep it that way or go with a full 6 channel amp and get a new amp for the Boston Acoustic G3 sub that I have.
    Arkansas
    I ran a 4 channel for the 6 cabins and have a dedicated sub amp. That gives me somewhere around 89-90 rms to the in-boat coaxials, which is what they are rated at.
    The 6-channel pushed about 10 more rms per channel but it was $100 more and i knew i wouldn't need the extra wattage because even at 80ish rms, the cabins will likely be turned down.
    Bet David will be the only one that can answer your light ring question.
    I went Krypt so i could have HLCD's on the tower and a pair of those weren't much more than a pair of on sale Bullet coaxials. I know David will preach against the Krypts but it fit the bill for me perfectly. They slide right into my factory cans. I think your only other option (outside of coaxial) is a Kicker setup.
    Here is a comparison of the Bullet Coaxial and the Krypt HLCD sitting side by side. I ran the Bullet Coaxial in the tower last summer.
    2016 Moomba Mojo
    Feb 2008
    Traverse City, MI
    My Krypt grills look like your Bullet grilles, of which believe they are copies. I like yours better actually.
    2013 Outback V
    Sep 2009
    Copperas Cove, TX
    I run my 6 Bullet coax speakers on 4 channels and a JL sub on 2 channels on the JL G6600 amp
    Nov 2003
    Land O Lakes, Florida
    and just where was this tidbit of info before I started?????
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
