Thread: Fill Holes
03-26-2011, 03:45 PM #1Member
- Jul 2009
- Nor Cal
- 80
Fill Holes
I have some existing holes from an old tower and will be trying to mount a new tower approximately where the old one was, but mounts will not exactly match. I plan to fill all the holes knowing I will be drilling some new ones, but believe some of the new holes may at least partially go where the filler is. I have a gel coat repair kit I planned to put over the filled holes knowing its not going to be an exact match. The gel coat kit directions state it wont stick to an epoxy, which I beleive MarineTex is and has been recommended as being drillable and tapable. Is there a better strong filler I should use like Kitty hair or Bondoglass?
2005 Outback DD
03-26-2011, 10:56 PM #2Senior Member
- Sep 2010
- Lighthouse Point, FL
- 211
Get some wooden dowels and a drill bit a little bigger than the dowel. Drill out the holes and cut the dowels about a 1/4" shorter then the hole. Champfer the ends of the dowels. Use regular polyester resin and coat the dowels. Place the dowels in the holes while the resin is still wet. When the resin sets up you can fill the low spots and finish with the gelcoat.
Now when you drill the new holescyou will actually have some meat there to support the new tower. It's pretty simple to doREALLY????
03-27-2011, 06:28 PM #3Member
- Jul 2009
- Nor Cal
- 80
Is Formula 27 an acceptable resin?
2005 Outback DD
03-27-2011, 11:08 PM #4Senior Member
- Sep 2010
- 211
any polyester resin will work. You can get it anywhere....home depot, lowes and just about any auto parts store
REALLY????
03-28-2011, 10:23 AM #5Member
- Jul 2009
- Nor Cal
- 80
Great, thanks for the help. Oh, are the wood dowels necessary or would I be OK if I injected the holes with straight resin. I'm a little paranoid about putting wood somewhere there is none (scared of it getting wet and rotting).
2005 Outback DD
03-28-2011, 10:35 AM #6Senior Member
- Sep 2010
- 211
The little amount of wood from the rowels is nothing to worry about besides you are coating them w resin before you put them in. You could try just filling the holes w resin but I have never had good luck w any kind of strength that way. Resin by itself is very brittle and doing that you may be prone to cracking.
Just my .02REALLY????
03-28-2011, 03:40 PM #7Member
- Jul 2009
- Nor Cal
- 80
Got it. Makes sense. Thanks for your guidance.
2005 Outback DD
