Results 1 to 10 of 15
Thread: Kenwood Head Unit Replacement
03-21-2011, 05:49 PM #1Junior Member
- May 2010
- San Antonio, TX
- 25
I need to replace my Kenwood Headunit on my 2006 XLV GG. I would like to replace the headunit and still have the factory remotes at the driver side and transom still work. My current headunit has the seperate wire for the remotes. Anyone know which headunit I could buy that would work with my factory setup? Or would it be better to replace the headunit and remotes with something better?
Thanks2006 Moomba XLV Gravity Games
03-21-2011, 07:39 PM #2
I recently replaced my kenwood HU with the KMR440U it has a USB port so you can use a thumb drive. It will also work with the factory remotes by connecting it to the steering wheel remote wire. But the good thing about it you can purchase the Kenwood KCA-RC107MR digital remote and control every aspect of the stereo from the drivers seat. You can also check out some pics of my install in my album.
I know alot of boaters use the automotive Kenwood stereo's because of the output line voltage and you can still us the factory remote thru the same steering wheel remote wire. But if you ever want to upgrade the driver side remote to a digital remote you will have to stick with a marine kenwwod like KMR440U.Patrick
5 light- light bar. 2015 RAM 3500HD Dually 6.7 Diesel w/ Aisin 6 speed tranny
Live life today!
03-21-2011, 08:21 PM #3
is the steering wheel remote wire the blue and white wire. i tried replacing my HU with the kenwood 248U and the remote didn't work. i took it out and returned to best buy. i still need a head unit and have been looking at the 440U. is the wire labled something? my dealer told me any HU w/the blue and whit wire would work, but that one did not.
03-21-2011, 08:59 PM #4Junior Member
- May 2010
- San Antonio, TX
- 25
Thanks for the info. Will I have to replace the wiring harness in my boat to accomodate the 440U or will I be able to unplug my current wiring harness, remote wire, and radio wire from my current head unit and just plug in the 440U and have it work like normal? Wasnt sure if it had a seperate remote wire or if it was built into the wiring harness.
Thanks for the help2006 Moomba XLV Gravity Games
03-21-2011, 09:54 PM #5Patrick
Live life today!
03-21-2011, 10:15 PM #6
You will have to replace the existing radio pigtail with the one that comes with the KMR440U. It has a couple additional wires that the factory Kenwood does not have. One of them is the blue and white steering wheel volume control wire which would be wired to the existing factory remote wire. The new pigtail is very simple to do all of the wires are the same color from the old one to the new one, just has a couple additional wires which you will not use accept the blue and white wire. It does have a seperate plug in (multipin connector) for the digital KCA-RC107MR driver side remote if you decide to go that route. Highly recommend it controls the complete stereo form the driver seat. The cage will also have to be replaced that the stereo sits in the dash. The 440U is slightly longer and the trim plate will not snap in place if you don't replace the cage. There is some tips in my album for doing this. I picked my new 440U up for $145.00 off of ebay. Let me know if you decide to go with it and need any help.
Patrick
Live life today!
03-21-2011, 11:11 PM #7
ok i did a little bit of research and i think the steering wheel control wire is blue and yellow. the blue and white wire is an antenna wire for cars with a motorized antenna. the 248u didn't have this but the 440u does. thanks for the advice.
03-22-2011, 07:55 AM #8Patrick
Live life today!
03-22-2011, 08:31 AM #9Senior Member
- Jun 2010
- Lake Houston
- 656
I just ordered this one.....
http://www.lafayetteradio.com/html/d...sp?search=1873
Same price as 440U except it ALSO has a wireless remote AND 4.0V preouts.2013 LSV
2005 LSV - SOLD
03-22-2011, 09:48 AM #10
I could be wrong, but I believe the specs they give on that site is incorrect. The out put is only 2.5v. check the kenwood site. There is also no way to hook up a digital driver side remote, just the factory style remote thru the steering wheel wire. Also the only place you can buy that HU if from 2 place on the web and if you look closely they are the same dealer. So I don't know if they have that built for them or what. This has actually came up on some other threads in this forum.
Patrick
Live life today!
