Results 1 to 9 of 9
Thread: 5 Pole adapter
03-20-2011, 02:46 PM #1
5 Pole adapter
Getting ready to pick up my new moomba sometime and just trying to get prepared. Right now I have a 4 pole for my trailer lights and the Moomba trailer has a 5 pole. Is there any adapter that I can just plug in and remove when I want to. I'm just thinking if my buddy pulls my boat he'll need the adapter too.
03-20-2011, 04:03 PM #2
does this have an adapter to plug into my 4 pole and allow me to plug in the lights and breaks for the 5 pole
03-20-2011, 04:21 PM #3
The 4 pole on the vehicle will plug into the 5 pole trailer, I've done it several times with several vehicles. Flipping it and turning the headlights on also works like a charm for reverse!
2013 Outback V
03-20-2011, 04:49 PM #4
The 5th pole is for the back up lights on the trailer and it also activates the back up surge solenoids which allows you to back up. If this is not activated you will not be able to back the trailer. They make a 7 to 5 adapter but not a for 4 to 5 adapter. The 4 pole does not have back up lights in the circuit. So you will either have to wire a 5 or 7 pole for the vehicle or do as ED or Ian suggested. Or just don't back up.
Patrick
5 light- light bar. 2015 RAM 3500HD Dually 6.7 Diesel w/ Aisin 6 speed tranny
Live life today!
03-20-2011, 05:22 PM #5Senior Member
- Feb 2005
- Ottawa, Ontario, Canada
- 718
The trailer should come with a small mechanical lockout device to enable backing up without the electrical connection. The OP should find that and put a big tag on it, because it's easy to lose! My marina operator just zip-tied it to the trailer tongue because it kept falling out immediately upon stopping.
2005 XLV, upgraded ballast, Comptech swivel wakeboard and hydrofoil racks, Monster cargo bimini
03-20-2011, 10:42 PM #6
I had the same thing with my explorer. Here is what I used. http://www.etrailer.com/Wiring/Hopkins/47515.html Cheap, and simple. I picked mine up locally.
You wont be able to get around an additional wire wire on the tow vehicle if you want 100% function. Without the 5th pin, you just wont be able to back up the trailer, unless you use one of the previously mention tricks.2003 Outback, Assault EFI, (6) Polk Audio DB651s, JL Audio M6600 amp, JL Audio M1700 amp, JL Audio 10w6v2 subwoofer
03-20-2011, 10:54 PM #7
i saw that and thought it might be useful. What is the blue wire used for? Sorry I am not a very mechanical person.
03-20-2011, 11:12 PM #8
The blue wire is for reverse. You need reverse to back up the trailer (into garage or landing). The trailer is equiped with brakes that use he forward momentum pressure of the boat/trailer pushing on the ball to activate, such as when the tow vehicle is braking. This same pressure is there when you reverse, or backing up the trailer. The trailer is equiped with a solenoid to prevent the brakes from activating, when backing the trailer. The solenoid needs a 12volt signal when the tow vehicle is in reverse (the back up lights). This is what the blue wire taps into, the reverse lights, thus allow you to back up the trailer w/o activating the brakes.
If you don't have the blue wire, or anything else, you wont be able to back up the trailer due to the pressue of the trailer brakes. I know my tow vehicle wont.
Hopefully that helps you out.2003 Outback, Assault EFI, (6) Polk Audio DB651s, JL Audio M6600 amp, JL Audio M1700 amp, JL Audio 10w6v2 subwoofer
03-21-2011, 12:31 AM #909 21v LAUNCH
99 Outback LS. Sold
Doug
