Results 1 to 3 of 3
    Jun 2004
    Default '04 XLV ballast problem
    Why would the portside, stern ballast bag be filling up when underway without the pump on. is there a main seacock that should be closed, or am I missing something. Your help greatly appreciated. KC
    Feb 2003
    Maryville, TN
    Default Replying to Topic ''04 XLV ballast problem'
    The bag is probably filling because a swicht on a valve has flipped over. The Ballast system fills through one pump and then hits a filter then a manifold system. Each bag has a switch that opens up a valve for water flow. I bet the switch has been flipped on your portside stern bag. Look in your owners manual under ballast sytem and it should show you how to correct the problem.
    Jun 2004
    Thanks Jon for the reply...will give it a try.
  1. Yet Another Problem w/ 07 XLV GG
    By bradcraig78 in forum Service & Repair
    Last Post: 05-15-2007, 07:01 PM
  2. don't no my problem do you know
    By chummygyn in forum Service & Repair
    Last Post: 04-24-2006, 05:43 PM
  3. 04 LSV Ballast problem
    By tk42 in forum Service & Repair
    Last Post: 04-25-2005, 10:00 PM
  4. Skeg problem...
    By jon_n_andrea in forum Service & Repair
    Last Post: 02-20-2004, 02:52 PM
  5. problem
    By in forum General Chat
    Last Post: 06-30-2003, 07:20 PM
