Results 11 to 20 of 21
Thread: Trailer Wench???
03-04-2011, 10:41 AM #11My Mom said I'm not allowed to get wet!
03-04-2011, 11:55 AM #12
03-04-2011, 11:55 AM #13
fyi, adapter from boatmate is over $80. they don't stock it, don't make it, but can order it, presumably from the same people that everyone else is getting it from. boatmate doesn't stock it since it's not made by fulton. I would suspect that they are trying to avoid any sort of liability issue if it should damage the trailer.
looks like smoothwatersports and chucktronics are the 2 so far that carry it.'06 Supra Launch 20SSV-gone but never forgotten
03-04-2011, 11:56 AM #142013 Outback V
03-04-2011, 12:40 PM #15
I never really considered the adapter I guess. I was planning to just cut off the old plate, hit it with some paint, then bolt the new Fulton in the same place.
03-04-2011, 01:17 PM #16
it'll never look good if you do that. the new fulton plate for the f2 really needs to be welded on. seems that the plates should run in the $35 range. I can't get a buddy to come over for much less than that with a welder, not to mention grinder time/paint time and this way looks somewhat factory
03-04-2011, 01:43 PM #17
Somewhere I saw a Fulton bolted on with U bolts, same way the spare tire mounts get put on. But now that you mention it that does seem a little dicey to mount it that way.
03-04-2011, 02:13 PM #18
The last one I saw flush bolted to the stock mount and had threaded holes for the Fulton. Best looking setup so far and no welding neccessary.
Here's a pic.Last edited by Razzman; 03-04-2011 at 02:16 PM.
03-04-2011, 02:19 PM #19
03-04-2011, 11:47 PM #20Senior Member
- Feb 2005
- Ottawa, Ontario, Canada
- 718
Morgan, how long is the strap in your current winch? The original strap on mine was 10'. When it wore out and ripped, I could only find a 20' replacement quickly. Due to the increased radius when it's almost winched in, it's much harder to get that last foot or so done. The winch is under far more load than with the original, shorter strap. I found a 15' model on-line somewhere and will order it.
2005 XLV, upgraded ballast, Comptech swivel wakeboard and hydrofoil racks, Monster cargo bimini
