Results 11 to 18 of 18
Thread: Mysterious trailer damage
02-03-2011, 02:01 AM #11
Yep, tire hit the fender and pushed it in. Excessively large speed bumps at a faster than normal speed???? Cut a turn too tight and hit a curb??? Drive the route again and check it out.
1998 Mobius
310 HP PCM
SOLD
02-03-2011, 04:34 PM #12
02-03-2011, 05:50 PM #13
Just unbolt the fender and take it to the body shop and have it fixed, no need for the boat to sit at the bodyshop
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
02-03-2011, 06:03 PM #14
I had my fender fixed this fall when someone backed into the front of the fender. One body shop doesn't do trailers but another one did. The estimate was to replace the fender (single axel) but the fender is welded on and I had the boat on the trailer but I loaded it away from that fender but it was still too close for a cutting torch. They did a fanastic job of straightening it out and it was much worse than what you have. The problem is one fender looks much better than the other and is obvious with the boat off the trailer. It still cost me the deductable and it was a $1,000 total to do the work. Personally, I would try to pull it out myself and use some touch up paint if needed.
1998 Mobius
310 HP PCM
SOLD
02-03-2011, 10:15 PM #15
You can also just buy a new fender for a couple hundred off the boat-mate site. Then take it to the body shop get it sprayed. Then re-bolt it shouldn't be more then 500 i think
[COLOR="#696969"]
02-04-2011, 12:20 AM #16
Thought I would post up , it won't make you feel any better but here goes. We were leaving for lake powell one time with the boat and had to make a stop for something . Anyway we were leaving the store and turning onto the main street. I stopped the rig kind of in the middle of the street so I could swing it to make a right turn. Did the turn , was driving down the street and my friend says " I think you hit a car with the boat trailer" . Well I didn't feel it nor did I look in the right hand mirror on the truck when I turned. No one got a citation and we continued on . It did dent the fender but not too bad. Never did fix it and sold the boat to buy my current Moomba.
Jim05 Mobius lsv , ballast system , stereo, etc..
02-04-2011, 10:55 AM #17
Ahhh HAAA now i know who owns the Moomba that hit me a couple years ago. Dammit man i had to drop 80 bucks for a new turn signal because i tried to squeeze past you.
[COLOR="#696969"]
02-05-2011, 02:36 AM #18
Oh yea right...
