Results 1 to 8 of 8
    Nov 2009
    Murfreesboro, Tennessee
    Default windshield spread
    I am tired of the walk thru window getting jammed between the dash and frame. Has anyone here fixed this problem on their boat and how did you do it. If you have some pics it would help.
    99 Moomba Outback with lots of work
    Jan 2003
    Minnesota and Wisconsin
    I had my dealer remount the windshield on my 99 Mobius. Lasted about a year. Mine does not get jammed, but it is definitely wider at the top.
    Mar 2003
    s.e. washington state
    I added a screw to the windshield top frame next to the wing window on the port side (2 total on that side). It prevents the top frame from pivoting and I haven't had that problem or the frame coming off the glass since. I also trailer with the window closed.
    1998 Mobius
    310 HP PCM
    Oct 2005
    Durham, NC
    I "fixed" mine and it works much better. Check out my Mods post for some pics.
    https://forum.moomba.com/showthread.php?t=10662
    Brian Roberts
    2001 Outback DD
    Nov 2009
    Quote Originally Posted by NCSUmoomba View Post
    Thats what I was looking for. THANKS !!
    Oct 2005
    Durham, NC
    I will say that the only issue I had was that I did this on the trailer. When I put it in the water, it was too tight. I kind of have to spread the windshield a tiny bit to get it to fit now.
    Brian Roberts
    2001 Outback DD
    Apr 2011
    Rosharon, Texas
    Looks great dude.
    Aug 2009
    Montana
    mine would only get wedged every now and then usually when riding in rough water. I found the fix was to replace the rubber seal on the walk through window with new weather stripping (thicker padded stuff than OEM) and found some at the local Lowes store.
    After install the clips that hold the walk through window down are very tight and keep the window snug and no problems since.
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
