Results 21 to 23 of 23
01-17-2011, 01:27 PM #21
Actually the 2010 and 2011 Moomba Cruise are Speed based, not RPM based, and mine holds speed real well even through turns. It aint' fancy, but it gets the job done! As mmandley noted, if you shut off the engine and leave the cruise turned on, when you start up the engine and try to go somewhere... it is a bit confusing throwing the throttle wide open and not going anywhere LOL! All I would add is the ability to dial in a speed at idle when first starting the engine for set... but it only takes a few seconds to bring her up to speed, set the cruise, throttle down and let the rider gear up...
Kraig - 2010 Outback V
01-17-2011, 02:50 PM #22
Yea im not sure why they changed but i know mines RPM based as right now speedo was jumping all over the place. I think my new water temp gauge is adidng turbulance sometimes or something. i plan to swap the paddle wheel and the temp places under the boat to see if it fixes the issue. We just used the GPS last summer to see what speeds we were going.
As for the Moomba Cruise vs the PP and Star systems, i am not trying to compare by any means, both of the other systems are fare better then Moomba cruise i was saying that Moomba Cruise is very usefull if you understand it.
Once i see the extra cash in my budget i will be upgrading but as of right now i dont see the benefit for the purchase. Other things i want to get first.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
01-23-2011, 12:41 PM #23Senior Member
- Jul 2010
- Northern VA
- 132
I know it's not fancy, but I'll also agree that Moomba Cruise is very useful and gets the job done. It would be nice to dial in speeds ahead of time. And the shut the boat off reset thing took me a while to figure out what was going on- really drove us crazy.
But now knowing how it works I find it completely sufficient. Not perfect. But holds speed through corners well too, as Ksmith said 2010 MC is speed based.
