Results 1 to 3 of 3
    Guest
    Default Why change oil @ winterization
    Makes no sense to change oil before I put it up for 3 months does it???
    May 2003
    south east michigan
    Default Replying to Topic 'Why change oil @ winterization'
    Contaminated oil has acids in it that will eat bearings.Better to let it sit all winter with clean,fresh oil.
    jy
    Aug 2002
    Maryville, Tn.
    That is a good call. There are so many myths and old wives tales as to when to change oil, before or after winterization. Personally, I do mine when I put her up for the winter, that way, in spring, it's insert plugs and connect hoses, do my safety check of all high risk inspections (fuel,steering,electrical) and go. The water from any condensation contaminating the oil will evaporate several minutes into regular operating temperature. Most dealers will do it at winter set up because they will be so slammed come spring. I guess when setting up and storing your own boat, it's what works best for you. Just as long as she is winterized properly. Brian Raymond
  1. winterization
    By NC05LSV in forum General Chat
    Last Post: 10-04-2007, 09:04 PM
  2. First time out after winterization
    By Chief Hawkeye in forum Service & Repair
    Last Post: 05-24-2006, 01:35 AM
  3. Do I need winterization?
    By marchina in forum Service & Repair
    Last Post: 08-25-2005, 12:19 PM
  4. winterization
    By BUSHSTER1 in forum Boat Owners
    Last Post: 12-11-2003, 03:38 AM
  5. Winterization
    By Vdawg in forum Service & Repair
    Last Post: 01-29-2003, 10:04 PM
