01-03-2011, 04:41 PM #1
Batteries - What does "group" mean
Now time for Battery 101 ...
With all this battery talk. What exactly are we looking at? What are the different sizes and "groups" we should be looking at? Crank and Accessory?2016 Moomba Mojo
2006 Supra 24SSV - Traded
01-03-2011, 04:55 PM #2
'Group' means a size classification. However, its a little tricky. With a Group 24, 27, 29, 31, etc. the capacity gets progressively larger. A Group 34, Optima for example, is actually smaller than a Group 24. The Group 34 will fit a Group 24 case with lid but since it is not as tall it gets to be more work to fit it into a Group 24 tray and bracket. Factory Moomba uses Group 24 provisions.
Use the 'Group' for a reference to mounting. A Group 31 is still a manageable size and weight. Batteries with greater amp/hour capacity are generally larger but definitely heavier. Focus on the maximum amp/hours.
Earmark Marine
01-03-2011, 04:59 PM #3Al
01-03-2011, 05:02 PM #4
This build is going to be the death of you an I.
01-03-2011, 05:06 PM #5
01-03-2011, 06:43 PM #6
kg, only if you have the optional hotshoe for the troller. if it's hand-operated, you're golden
01-03-2011, 07:05 PM #7
You two on overload yet?
