Results 21 to 30 of 39
Thread: In-boat cooler insulation
01-27-2011, 07:06 PM #21
01-27-2011, 08:40 PM #22
01-28-2011, 12:34 AM #23
01-28-2011, 12:39 AM #24
01-28-2011, 11:37 AM #25
I really like that idea. You're right it would be tough to undo. But assuming you did it clean I can't think of why you'd want to remove it. It's just wasted space anyway right? I might be hesitant to try to foam the bottom side though. Maybe some rigid foam board insulation for the bottom and expand-o-foam for the sides?
01-28-2011, 03:16 PM #26
Could you not spray foam insulate it out side of the boat, then cut away any foam that binds or prevents the cooler from seating all the way back in the compartment?
09 21v LAUNCH
99 Outback LS. Sold
Doug
01-28-2011, 03:30 PM #27
01-28-2011, 03:33 PM #28
I am sure I remember that someone tried this and it didn't work worth a crap.
01-28-2011, 03:40 PM #29
Found it. It was Razzman. Her's one of the threads that mentioned it:
https://forum.moomba.com/showthread....ghlight=coolerMy Mom said I'm not allowed to get wet!
01-28-2011, 04:05 PM #30
Yeah I tried just about everything to insulate that POS and nothing worked! Now it's a Koozie & small item repository
As i said before I tried HVAC insulation, Foam sheet in various thichnesses and densities to no avail. I even put insulation on the bottom of the seat! Unless you encapsulate the entire cooler with at least an inch of foam and find a way to seal the seat at the base it's useless to even try imo.
Here's my beef with it, SC knows it's a POS and very easily could have rectified that way back with an actual insulated cooler like some of their competition. I mean seriously, if it doesn't keep things cool then why even have it? Leave a space and supply a real softside cooler or something!
So on a sidenote; when cleaning up the boat for winter storage my wife was cleaning that useless space and called me over to show me a large crack across the cooler bottom! How do you like that, couldn't even use it as a cooler now even if i wanted to!2007 Mobius LSV
