Results 11 to 20 of 22
Thread: Tire age
12-15-2010, 07:42 AM #11Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Tire manufacturers blend UV protectant into the rubber compounds used for sidewalls. Never had any problems using tire shine products.
06-13-2011, 12:14 AM #12
Just blew the right front boat trailer tire. 4 new ones will be installed tomorrow
06-13-2011, 12:20 AM #13
I now keep my trailer at the marina and only pull the boat out at the end of the season and have it winterized and stored at the same marina so I put less than 200 yards per year on my tires.
2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
06-14-2011, 01:42 PM #14
This happened to me when I was bringing the boat home from storage the Friday of Memorial Day weekend. I have a tandem axle trailer and one tire blew due to dry rot. Checked all the other tires and they were dry rotting as well. Had to go and buy 5 new tires...trailer didn't have a spare so I bought a wheel to go along with the tires...trailer still had the original tires on it from when purchased new in '05. Fun times...
Skate: LF Faction 44
Surf: LF Custom Quad & XXX
Tow Rig:
06-14-2011, 02:18 PM #15Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
06-14-2011, 03:01 PM #16
We blew one Sunday. Right Rear, and yeah, you guessed it, being in the rear it caught hold of the fender, folded the fender complelty in half. My spare was brand new, so now I'm buying 3 more new ones and hoping I can get the fender beat back to straight.
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
06-15-2011, 02:23 PM #17
i got 4 new carilse sport trails. 600 bucks later i made it home. hopefully i wont have to worry about it for a while now
06-15-2011, 04:44 PM #18
Check 4WP for Prices
I'm holding out as long as possible for new tires on the trailer which hopefully I won't regret. When I got new tires on my truck a couple months ago I asked if they had trailer tires and they did. $320 mounted and out the door for all four 205/75/14! I can't recall the brand whether it was Carlisle or Goodyear or ??? but it was a name I had come across before shopping around online and had gotten decent reviews.
This was at a 4 wheel parts warehouse. They have locations all over the lower 48. Anyone in need of tires may want to check them out. Last place I would have thought of for the trailer but that price is hard to pass up!So when is this "old enough to know better" supposed to kick in?
06-15-2011, 04:57 PM #19
That sounds pretty darn good.
06-16-2011, 08:38 AM #20
Trailer tires have 2 main factors working against them for wear and tear, on tandems is the side ways drag the front axle gets when turning and everyones wear is leaving the boat outside.
I highly reccomend if you keep you boat out side that at the end of the season you treat the entire tire with a rubber compund that helps hold the moisture. This will slow the dry rot issues, and those that use the tire goo to make them shinny, well i hope its really good stuff. I stoped using tire goo on my tires after my F150 tires dry rotted with 36K and 3 years on them.
Another thing you can do and it sounds silly but i used to do this on ly old cars too that sat for months and months, keep the tires air up to reg pressure and eighter move the boat or jack it up and spin the tire to a new location for sitting. The same spot on the tire with no rotation causes uneven stress on the tire and can cause it to break down as well.
As for the boat i only use tire goo 1 or 2xs a year if the boat is going to a show. I keep her inside other then that and wash the tires when i wash the boat, so fare 3 years on the tires and no issues.
Im hopping to get the rest of this year out of the boat tires, as the truck will need new tires next spring and i want to upgrade the trailer to match the truck, or something close at least.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
