Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
    Jan 2010
    North Texas
    Default New Stereo Install Help Please
    Alright guys, here is what I am working with so far. I'm looking to make sure I have this right. 2 main questions:
    1. Do I have the tower speakers (Krypt) wired correctly to the Jl G1300 Amp? The Krypt are 4 ohm each, but I need it to be a 2ohm at the amp so each gets 150 watts. I originally thought that I needed to wire them in Parallel a the Roswell bar, and make on connection per pair to the Jl. However, looking at the JL, it has 2 + and 2 - inputs and says above them "min. 2ohm" So, if wired as my pic shows, straight from speaker to amp vs linking speakers, is the amp converting to a 2ohm output, or 150 to each speaker?
    2. For the 4 channel amp, where will i be best served tying the last 2 Polk's in?
    Also, any input regarding the rest of the layout is welcome. The Tsunami Distribution block is a fused block which holds 1 60 amp per each + output. It also is the ground distribution block, so it's all in one. I'm a bit unsure of how the dvc sub should be wired as well, but think I have it done the best and safest way.
    Thanks in advance.
    Jan 2010
    North Texas
    Based on this
    "You will notice that there are two “+” positive connections and two “–” negative connections. This is to facilitate multiple speaker wiring. The two positive and two negative connections are connected in parallel inside the amplifier. Connecting two speakers, each to one set of positive and negative terminals, will result in a parallel speaker connection. If only connecting one pair of speaker wires, it is not necessary to use both sets of connections."
    From the JL Manual, I believe I have it right, the amp parallels each pair itself at the input, converting to 2ohm. Which means I will be running 4 pair of 12g wire up the tower vs two pair and making a parallel connection at the speakers. Right?
    Arkansas
    as far as in boat go, depending on the amp ... i would use 3 channels at wire them at a 2ohm load on the amp. When you get to the pair of speakers, wire them in parallel. This way you have all speakers hooked up to the amp and all pushing the same wattage.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Lake Point UT....
    Not having worked with any of the product involved, check the owners manual of the jl amps for the tower. if you are looking for a 2ohm load, you can run a pair of wires up to the roswell tower, then join them either series or parallel up inside the tower cans. that's what I did. I wired mine pos+pos and neg+neg to get a 3ohm load on my bullets, but did all the wiring inside the cans. much cleaner than 4 wires running up the tower. you should have wiring ran through the cans that you can pull out, again, using the string theory to feed the new wire. iirc, the holes in the cans are already big enough for a solid 12gauge wire to feed through it..
    on the in-boat speakers, I ran my 4ch fosgate amp as follows: bow speakers ran to ch. 3-4 as a 4ohm load, one speaker to each channel. I ran the cabin speakers pos+pos and neg+neg, hooking up the 2 on the left side and the 2 on the rt side to ch. 1-2, presenting a 2ohm load to the amp.
    Jan 2010
    North Texas
    Alright, So if I stick with the original plan, which was to make one run up the tower, (the 4 conductor 12g that KG linked to), then join inside the Roswell as shown, that creates a 2ohm...correct? What I drew is running 2 + and 2 -, then before the speaker, adding a connection to run to the other. Make sense?
    And Kg, is this what you are referring to for cabins? Does 6 speakers running to the amp like this equal 2ohms per speaker?
    Sorry for the silly paint drawings, but I am a visual learner, seeing it in text vs pic is night and day for me.
    Lake Point UT....
    you are correct on the tower speakers. run the 4wire up the tower arm and once you are within the first can, split it off to the 4 speakers.
    now on the 4ch kenwood amp, run ch. 3-4 with a single bow speaker on each channel.
    run ch 1-2 with the 4 cabin speakers wired the same way as the tower speakers. that's what I would recommend. this will create a 4ohm load on 3-4 and 2ohm load on 1-2. you can use the gains to adjust the bow down just a little so they are more balanced.
    Jan 2010
    North Texas
    Got it, thanks sandm. appreciate your advice. I updated my saved pic to what you said so i wont forget. lol
    Arkansas
    ok, just a general question. not trying to influence the outcome ..
    why not run the bows off just the 3rd channel just like you did the cabins on channels 1 and 2. This would leave the 4th channel empty.
    The reason i ask about it is because from most specs ive read on amps, you get more RMS from a 2ohm load at the amp opposed to the 4ohm load you have when you split the bow between channel 3 and 4.
    Does that make sense? I'm just learning the ohm loads and how that works.
    2016 Moomba Mojo
    Jan 2010
    North Texas
    Does hooking up mulitple 2ohm loads to the amp lower the "overall" below 2, or how does that work? Like KG said, what is the advantage of running to all 4 like you suggested, as i drew in my last pic, or what he suggested in the 2nd pic?
    Lake Point UT....
    I am sure one of the resident audio dudes will chime in on the 3ch issue. personally, I would not think it would be good for the amp to run 3 out of 4 channels, but maybe it doesn't matter. what that will do tho is completely ruin your bow soundstage, as you now only have 1 side of the left/right equation going to one area. take your home stereo and turn the balance all the way to one side and listen to the music you lose. music has a left/right, not one signal sent to both sides..
    now onto ohms and load, I don't know what amp you are using, so lets take this one:
    http://my.kenwood.com/Car_Entertainm...fiers/KAC-M645
    it's going to deliver 40wpc to each front bow speaker. 40wpc into a 4ohm load=40 to each front speaker.
    your rear shows 2=4ohms=2ohm load. amp is rated 60wpc into 2ohms, but each speaker is going to receive 30wpc, so your bow will be a little louder theoretically, but you also have 1-6.5 up front and 2-6.5's in the cabin=2x surface area producing music, so your cabin may end up perceived louder with less power and more drivers. that's part of the reason for gain adjustment.
    any amp is rated 2ohm stable for each channel, so you can wire a 2ohm load to ch 1, 2ohm to channel 2 and so on. this would not make 1ohm across the entire amp, but 2ohm/channel.
