Results 1 to 10 of 18
Thread: New Boat Owner
    Default New Boat Owner
    Hey Guys,
    I just bought a 2008 Mobius LSV and have a few questions about it that I think yall may be able to help me with.
    1. Where is the drain plug to drain the water out of the engine block?? This may sound like a stupid question but I have no idea where it is.
    2. My boat did not come with an owners manual and I was wondering if the bilge pump on these are automatics or the do they run constantly when the switch is on?
    3. When I folded my tower down after the last time I went out the two support pieces on the back fell and I was unable to catch them, the hit the gel coat pretty hard and chipped/cracked it. can this be repaired and if so about how much would it cost?
    4. Where can I get a pump to suck the oil out of the motor so I can change the oil?
    Yeah, as you can see i am definitely a novice at this stuff.
    Nov 2003
    Land O Lakes, Florida
    my answers
    1) no idea myself as im in florida and have no need to drain
    2) pumps are auto on if enough water is present, and will run if you switch it on
    3)use 2 people to lower it, and yes it can be repaired-not sure how much
    4)overtones.com, barts.com, tractor supply stores, harbour freight. jsut get a manuall vacum pump one. dont bother with the piece of crap battery operated unit
    Welcome to Moomba ownership and the forums
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    Sep 2005
    Claytor Lake, VA
    Link to owners manuals under About Moomba then Archive tabs at the top of the page.
    http://moomba.com/downloads/owner_manuals/moomba_08.pdf
    Engine block drain plugs are in the center on each side of block below the heads. look for brass 1/4" NPT pipe plugs.
    Link to Indmar engine owners manual.
    http://indmar.com/About/ContactIndma...Presentweb.pdf
    Sep 2009
    Salerno Lake, Haliburton, ON, Canada
    Search for winterization on this forum and you can see everything you need. Good luck with the chips.
    06 LSV
    2 - 750lb Fatsacks, Custom Sunbrella Cover and Bimini, Kenwood KMR440MU and Amp Bazooka Tower Speakers, Aerial Mirror, Stargazer, 4 Port Heater.
    Toys - O'Brien Natural, CWB Pure, IS Yellow Loogie, CWB Ride, Hyperlite Voyageur for the kids.
    Henderson, NV
    I highly recommend the pela 6000 pump. I used one of the small ones that hooks up to a drill and it was a pos. anyone wants it, just pay me for shipping
    got the pela off amazon earlier this year for around $50 and it was amazing. sucked the oil dry in no time at all and with no effort at all..
    Jul 2002
    London Ontario Canada
    As far as the gellcoat......an idea is to add 2 more moomba step plates and mount them over the chipped areas so now you have a rest place for tower when its down or for the next time they drop
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Default step plates
    Quote Originally Posted by DOCDRS View Post
    As far as the gellcoat......an ideas is to 2 more moomba step plates and mount them over the chipped areasonow you have arest place for tower when its down orforthe next time they drop
    Where do I get these step plates that you speak of and how much do they cost?!? i was thinking about putting something there for them but was having a hard time deciding what to put there without it looking tacky.
    im in egypt right now and the temp back home his hitting as low as 29 at night and my new toy has not yet been winterized. worrrriiedd
    Nov 2003
    on my lsv the step plates will not help cause when the rear legs of the tower are folded down they dont hit in the middle of the gun wale-they hit on the outside
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    thats odd cause mine hit dead center and there is a chip and crack on both sides where they land. i figured if you put wing bolt back in the swing arm a few threads and lay it down it rests on the plastic of the bolt instead of the hard metal of the arm. but still step plates would be nice
    Jul 2002
    well I picked up Two Supra step plates from my dealer....i think they were about 40 or 45 a piece..... expensive but look good
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
