Results 1 to 7 of 7
Thread: Water in ski locker
10-14-2004, 08:18 PM #1Member
- Dec 2003
- Texas
- 56
Water in ski locker
Does anyone know if they make a check valve for the ski locker so the water would drain to the motor compartment but not be able to return to the ski locker?
The BleuRueThe BleuRue
10-28-2004, 10:30 PM #2Member
- Dec 2003
- Texas
- 56
Replying to Topic 'Water in ski locker'
Can anyone help? I'm looking for a check valve to fit between the ski locker and engine compartment.
The BleuRue
11-01-2004, 10:08 PM #3Member
- Apr 2004
- 36
I have not heard of anything.......Have you checked with your dealer. And if you have and they have said no then you might be able to find something at a local parts store or even possibly and local hardware store.
SUMMIT
11-02-2004, 02:43 AM #4
Some type of check valve with a floating ball in the base that would float up and make a seal where you would get them beats me. Perhaps the hardware store or plumbing store. Good luck.
1998 Mobius
310 HP PCM
SOLD
11-02-2004, 11:08 PM #5Member
- Dec 2003
- Texas
- 56
Was hoping that someone had already solved this problem. I'll look around and see what I can find.
11-16-2004, 03:50 PM #6Junior Member
- Jan 2003
- Vancouver , BC Canada
- 18
Hey The BleuRue
On my old jetboat I had a flapper valve similar to the exhaust flappers that I got from the marine store. It was basically a plate that was screwed onto the transom which allowed the bilge to drain each time you accellerated. Does all this make sense ? No factory item exists that I know of. I do agree that it is a good idea.Seeking Flatwater
11-16-2004, 03:54 PM #7Junior Member
- Jan 2003
- 18
Update on bilge drain
Here is a link to the shop that carries the item I mentioned above
http://www.californiamarine.com/imag...ood/page64.pdfSeeking Flatwater
Water in center floor locker
By mschude in forum General ChatReplies: 5Last Post: 07-22-2006, 11:42 AM -
Locks for Rear Ski Locker
By gotmyboat in forum General ChatReplies: 4Last Post: 07-14-2006, 06:14 PM -
Size of LSV locker - for ballast
By jchamlee in forum General ChatReplies: 1Last Post: 07-13-2004, 01:01 PM -
LS ski locker modification
By lowdrag in forum General ChatReplies: 3Last Post: 07-08-2004, 02:23 PM -
Water in Ski Locker - Kamberra
By RickMcD in forum General ChatReplies: 1Last Post: 06-17-2003, 08:34 AM
