Results 11 to 20 of 22
  1. #11
    Mar 2003
    s.e. washington state
    I haven't always blown out the water in my exhaust but one time I disconnected the coil and turned the engine over to seat the impeller correctly (I don't pull mine) and quite a bit of water came out. I now raise the bow and turn the engine over (coil disconnected) for about 3-4 seconds. I have never had a problem before I started to blow the water out so I don't think there is much water that stays in.
    1998 Mobius
    310 HP PCM
  2. #12
    Aug 2009
    Montana
    Default Direct Drive Silencer Guts
    Well,
    When removing the Ultra Marine Silencers I had one come apart. Looks to be a defective set of mufflers if you ask me! Whatever sealed them has given way and the Inlet Side just slid out from the baffle. No cracks or issues there as previously thought.
    Should be a fairly easy fix with a little 5200 epoxy around the tube and slide it back together. But I'm certainly going to talk to Ultra Marine about it.
    Thought I'd post up some photos for anybody interested in what the inside looks like. Really just a 90degree downtube and then a 90up and out. The rest is all hollow.
    On a side note........there would be absolutely no way to get all the water out of them (except for the random total disassemble !
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
  3. #13
    May 2007
    Richmond, VA
    viking - Thanks for posting the pics. Please let us know what Ultra Marine has to say. - Deerfield
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
  4. #14
    Aug 2007
    Alpine, Utah
    Default Blowing the exhaust with air?
    How do you blow out the exhaust with air? Do you blow out through the gardenhose connectors after you unscrew them to drain the exhaust manifolds?
    Garn
    Garn
    2007 Mobius LS (Direct Drive)
  5. #15
    Default intake fog
    what is used to "fog" the intake and where can this be purchased??
  6. #16
    May 2007
    Richmond, VA
    rd - Here's a pic of the fogging oil. It comes in an aerosol can. Bought it at West Marine. I pull the spark plugs and spray directly into each cylinder. Fogging oil puts a layer of protection on metal surfaces to keep them from corrosion. - Deerfield
    2012 RAM Crew Cab
    Stuart
  7. #17
    Jul 2002
    London Ontario Canada
    what engine do you have?
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
  8. #18
    Quote Originally Posted by DOCDRS View Post
    ive got the 325 horse. those do not come with the cats do they? i know it says california emissions compliant on it or something like that so it may have cats. im not sure what california requires but i was thinking that only the 340 horse and up had the cats on it
  9. #19
    Quote Originally Posted by deerfield View Post
    i notice all these items say "marine". what does that really mean? i mean is that marine motor oil better than regular mobil 1 full syn? or the oil filter better than a regular filter?
  10. #20
    Aug 2009
    Montana
    If it has cats you DO NOT want to fog!
    2015 "NOT A MOOMBA"
