Results 1 to 8 of 8
    Jul 2004
    Default Electrical Problems
    ok, so I go out yesterday on the water and find a few problems with my new boat. I now have 14 hours on it, so I am getting close to getting it serviced for the first time. I am wondering if all these electrical problems could possible be linked to something that can easily be fixed.
    First, my blower will not come on anymore. The switch lights up, but the blower will not move. I checked the breaker under the swtich and it does not feel to be poped.
    Next, I noticed my fuel guage is not working. The needle is stuck way below "E", even though I just filled up. I know the fuel guage it not the most accurate thing in the world. However, before yesterday, it was atleast jumping around alittle, now its just off tot he side and not moving.
    Also, My 12v plugs dont seem to be working anymore, both of them, the one by the drivers seat and the one in the glove compartment. Im not real sure of the acc switched, so I tryed the swtiched in all the different configs. I could not get my 12v air pump to work, and I know it works since I tried it on my car when I got home.
    I have a 2004 moomba outback, without ballast.
    Any help would be great. I hope that its something easy to fix. Otherwise, it will have to wait until I get it to its first servicing at the dealer.
    Thanks!
    Feb 2004
    Default Replying to Topic 'Electrical Problems'
    I have a 2004 Mobius LSV and there is a main circuit breaker by the battery that controls all the accessories. I'm sure there is a main circuit breaker on your baot that feeds the circuits follow the positive battery accessory cable.
    Sep 2003
    Ventura, California
    whoopdedoo,
    So what did it turn out to be?
    I'm curious, what was the problem?
    Sep 2003
    Ventura, California
    whoopdedoo,
    Jul 2004
    Im not entirely sure where, but the cause of my problems was a single plug that had come loose. Dealership fixed it while I had it in for my 20 hour service. It solved all my problems.
    Aug 2003
    Howell, Michigan
    I had the same problems with the pcb boards coming loose continously ie. lights wouldn't come on, no bilge, etc. Finally getting fed up I got up under the dash and looked at it. The two boards were seperating due to vibration and the blade terminals would come apart. To resolve it, I reseated all of the blade terminals properly and squeezed the boards back together. I then took 3-4 small zip ties and secured the two boards together thru the screw holes at each corner of the board (not being used).
    I've never had the problem again. According to SC they were getting away from this setup. Mine is an '03 Outback, I would have thought the change to have been made by now..??
    Great boat....enjoy it...get out often!!!
    Mar 2005
    NC
    I am having the same problem with my blower not working. I have been trying to find the problem but so far no luck. I am only 7.5 hours into the break in so I didnt want to take it 1.5 hours away to get this stuff fixed just to drag it back up there in a couple more weeks. I am going to look at the board but didnt notice that when I checked earlier.....thanks
    Apr 2003
    Powhatan, VA
    Gasoline fumes are a lot heavier than air, so opening the cover won't remove the highest concentration of them.
  1. Electrical issues
    By in forum Service & Repair
    Last Post: 08-23-2009, 12:44 AM
  2. Electrical and physical heater problems - 07 outback V
    By rob.williams@gmail.com in forum General Chat
    Last Post: 06-12-2009, 06:10 PM
  3. 07 GG Electrical Failure
    By bradcraig78 in forum Service & Repair
    Last Post: 05-03-2007, 03:35 AM
  4. Power / electrical
    By sleepy924 in forum Service & Repair
    Last Post: 04-20-2007, 10:04 AM
  5. Electrical problem
    By bradenb12 in forum Service & Repair
    Last Post: 07-10-2006, 11:01 PM
