Results 211 to 220 of 433
11-09-2010, 06:51 PM #211
I have been watching this subject with great interest. So when I got to our garage this weekend,I looked in my bilge and ski locker and they were completely dry. The boat has been inside with the hatches open for 3 weeks. Just to see what would happen I jacked up the trailer until the rear touched the ground. After a few hours I had 4 gallons of water in a bucket under the wake plate. The boat was sitting level to slightly bow high before this. Any ideas?
04 LSV
11-09-2010, 07:44 PM #212
11-09-2010, 08:09 PM #213
As YDM said it's probably the same issue throughout the thread. Read the thread, check the pics, read the diagnostic and see if that's your issue. And remember one thing, if the water does get in there it won't come out on it's own due to the drop keel as you found out so you either have to correct the issue or do what you've just done.
For the record i had to do that on my last boat all the time due to the drop keel, and no it wasn't a Moomba.2007 Mobius LSV
11-09-2010, 08:11 PM #214Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
11-09-2010, 08:30 PM #215
This could simply be from water between the bilge and the ski locker, i.e., under the gas tank. I can do the same with my boat - the bilge and the ski locker can be dry but when I park on a steep hill, water runs out from the area under the gas tank, into the bilge, and out the rear drain hole.
As far as we know, the water trapped under the ski locker will not drain out to the bilge as it is trapped there.
See pic below. This is the area I am talking about.
11-09-2010, 08:51 PM #216
Thanks for the info guys. I did read all 21 pages but most of you said if water gets in there it cant get out. I really dont think I had 4 gallons under the gas tank. But maybe I did, but it could have come from under the ski locker. Anyway you can try and see if it helps. The water did not come out all at once it came out over several hours. I could have more in the bucket this weekend, I will see.Thanks again.
04 LSV
11-09-2010, 09:58 PM #217Senior Member
- Jun 2007
- St. Albert, Alberta, Canada
- 164
http://www.themalibucrew.com/
My buddy gets good use out of it. Seems alive and well.'07 Outback V
Ski|Board|Surf|Skate
11-09-2010, 10:12 PM #218
11-10-2010, 12:02 AM #219
11-10-2010, 03:17 AM #220
