Results 381 to 390 of 433
06-10-2015, 12:03 AM #381Junior Member
- Jan 2014
- 7
Just got to doing my today, got as much water out as I could but I can see it slowly accumulating. I'll come back tomorrow afternoon and see how much is in there. IMG_0638.jpg
07-01-2015, 01:29 PM #382Junior Member
- Jun 2015
- Utah
- 4
I just bought an '02 Kamberra in May of this year (2015). Noticed when I stepped in the ski locker the first time that water was sloshing underneath. Add me to the list of victims.
07-01-2015, 01:39 PM #383Senior Member
- Aug 2011
- 2,522
Water trapped between hull and ski locker subfloor
Still not sure what the bid deal is.. Few extra pounds for fuel consumption?
2006 Moomba Mobius LSV - Sold
07-01-2015, 02:59 PM #384Senior Member
- Oct 2013
- Ft. Collins, CO
- 688
07-01-2015, 05:22 PM #385
09-09-2016, 03:04 PM #386Junior Member
- Jun 2016
- 7
I bought a 2015 Outback V back in April of this year. I took my ballast bag out two weeks ago, stepped into the ski locker and go figure, I was standing on a wavy lake while the boat was up on the trailer. I figured I would try to drain it to the back, hooked my tractor to the ball and lifted the front end up until the trailer was nearly on the ground. It was a fruitless labor....... I too think mine is trapped. Sad day. I have contacted my dealer about getting it fixed and they're getting in touch with SC about it. I have to admit, I was shocked to find that this problem was spotted 5-6 years ago, and I'm seeing it in my boat now. Hopefully the warranty covers it, I bought it new, so I don't see why it wouldn't.
I wonder if the dealer would put an access port in for me instead of re-glassing it..... hmm.....
09-09-2016, 03:18 PM #387
should have been fixed in 2009 , but the access port is a quick and easy mod to extract the water.......
09-09-2016, 08:02 PM #388Senior Member
- Aug 2015
- Spokane, WA
- 262
I tore mine apart this winter. The water was never coming from the bow. It actually comes from the bilge. There is a failure between the deck / hull bond creating a passage for water under the bulk head that seperates the ski locker from the bilge. In addition, whom ever installed the ski locker drain installed it at crooked and failed to seal around it. I ended up cutting out all the deck fiberglass and pulling all the foam (which was soaked) from the bilge are, under the bulk head and under the ski locker out. Re-foaming, Re-fiber glassed the hull deck joint, bypassing the bulkhead ski locker drain with a new drain, sealing the entire thing with epoxy and a good 2-3 coats of bilgekote. I left the access hatches I cut initially in the ski locker to make sure water was no longer getting trapped.
2008 Moomba Mobius LSV
09-09-2016, 08:07 PM #389Senior Member
- Aug 2015
- Spokane, WA
- 262
Skiiers choice was very helpful in helping me navigate the structure of the boat.. However, it was very obvious once I figured out where the water was coming from that this is 100% a manufacturing and poor design issue. If I had bought my boat new I would have pushed a warranty claim and not backed down. They should be covering this issue under warranty. There is no excuse!
09-09-2016, 08:36 PM #390Senior Member
- Aug 2011
- 2,522
Re: Water trapped between hull and ski locker subfloor
Does it really matter? It's foam and fiberglass so it's not going to rot.
