Page 12 of 43 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 425
  1. #111
    Aug 2008
    Cottage Grove, MN
    1. mnpracing - 08 LSV
    2. cab13367 - 06 LSV
    3. T100 - 04 LSV (same hull as 06-08 OBV)
    4. Canuckle Head - 07 OBV (same hull as 04 LSV)
    5. GrantM - 06 LSV
    6. 09outback - 03 Launch SSV
    7. saskyrider - 05 LSV (same hull as 06-08 OBV)
    8. mk_deuce - 07 LSV
    9. Kojack -
    10. Moombadaze - 08 LSV
    Added Moombadaze
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
  2. #112
    Add me to the list too.
  3. #113
    Aug 2008
    Cottage Grove, MN
    5. GrantM - 06 LSV
    9. Kojack -
    11. brain_rinse - 08 LSV
    Added brain_rinse
    2008 LSV - Gone
    2013 other brand
  4. #114
    Apr 2008
    California
    So I take it you have this issue also, or you thinking hypothetically here?
    Hypothetically, BUT i have also noticed water in my locker as well when i know none should be there. I'm pulling mine out Saturday and taking to the lake to get it hot to change the oil, I'll check then. I won't be suprised if i do though.
  5. #115
    Sep 2009
    Vernon BC Canada
    I'm really having a tough time with all this water "under" our ski lockers coming from rain water over time. I have a great cover and have not put water over my bow once this year. I have not drilled a hole as of yet because I'm still reading to see the out come of this issue.
    Could the water be coming from under the gas tank in the older boats that do not have a drain plug under the gas tank??? Am I missing something here??
    2004 MOBIUS LSV
    2008 Tacoma
  6. #116
    Feb 2010
    smyrna, TN
    Add me to the list as well! 06 lsv
  7. #117
    Aug 2008
    Cottage Grove, MN
    Quote Originally Posted by T100 View Post
    T100 - look at post #76 of this thread. I'm thinking that water can, and is, entering anywhere that the black stringer structure is not sealed to the hull properly. So to extrapolate your comment above, water that is below the gas tank could be sloshing forward though a void in the sealant between the hull and the stringer structure, and then it settles below the ski locker because that is the lowest point in the boat.
    2008 LSV - Gone
    2013 other brand
  8. #118
    Aug 2008
    Cottage Grove, MN
    Default Tally of members with this issue
    5. GrantM - 06 LSV
    9. Kojack -
    12. wilemobius - 06 LSV
    Added wilemobius
    2008 LSV - Gone
    2013 other brand
  9. #119
    Sep 2009
    Vernon BC Canada
    Thanks mnpracing,
    So this is what I decided to do to get the water out for the winter. As soon as I started to drill water came flowing out and a lot of it. Water was right to the top. I went with the larger 6" access hole to shop vac the water out.
    Water is still leaking out as I covered up the boat, I'll vacuum more out tomorrow.
    2004 MOBIUS LSV
    2008 Tacoma
  10. #120
    Jun 2009
    Victoria BC Canada
    But it's not a defect though.............
    2007 Outback V
