Results 1 to 8 of 8
Thread: fuse box?
10-17-2010, 06:08 PM #1Senior Member
- Aug 2009
- 103
fuse box?
ok this is a bad question but i've look just about everywhere on my boat with out taking anything apart and i can't find my fuse box... i've looked thru the Owners Manual and can't find anything either... i should know this but sad to say i don't know where it is... thanks for any help! my boat is a 2002 mobius
10-18-2010, 10:38 AM #2Senior Member
- Aug 2009
- 103
no one...?
10-18-2010, 12:09 PM #3
The fuses/resets are the rubber buttons beside each one of your switches on your dash. If they do not reset when you push them in, you will have to do a little investigating ... maybe a ground. The below picture shows the rubber buttons under the switches.
2004 MOBIUS LSV
2008 Tacoma
10-18-2010, 12:18 PM #4
There may also me a master reset at the back of the engine. You'll see a big red button but you have to almost stick your head in the open clamshell to see it.
10-19-2010, 12:12 AM #5Senior Member
- Aug 2009
- 103
thanks for the info! i will be doing some looking around and investigating in the boat in the next few days!
thanks!
10-19-2010, 12:21 AM #6
On my 02 the only fuses that I know of are under the helm. Lay on your back and slide up under the steering wheel at the back edge of the dash is a fuse panel with about 8-10 fuses. Which ones are you looking for or what is your issue?
15 Mondo Surf Edition
02 LSV - Traded In
10-19-2010, 02:49 PM #7Senior Member
- Aug 2009
- 103
ok thanks, my acc switch is not working... the shop put my tower lights on my acc switch and my lights went out.
10-20-2010, 11:12 PM #8
