Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
    Sep 2009
    Salerno Lake, Haliburton, ON, Canada
    Exclamation Dropped the fog straw into cyliner?
    When following Cab's winterizing procedure I think I made a big booboo..
    I think I dropped the fogging straw into the cylinder (through spark plug hole). I shifted while lubricating and pop - it was gone. It was getting dark so I had to clean up and quit. Any ideas???? Help!!
    I'm going to try moving the flywheel tomorrow and see if I can see anything. My next step is a flexible camera from Home Depot.
    06 LSV
    2 - 750lb Fatsacks, Custom Sunbrella Cover and Bimini, Kenwood KMR440MU and Amp Bazooka Tower Speakers, Aerial Mirror, Stargazer, 4 Port Heater.
    Toys - O'Brien Natural, CWB Pure, IS Yellow Loogie, CWB Ride, Hyperlite Voyageur for the kids.
    Des Moines, IA
    I hate when stuff like that happens. Shopvac?
    Pensacola, FL
    How long is that straw? You piston can only be like 4" in diameter. Shop vac is a great idea.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Could also try one of those flexy shaft grabbers where there are 3-4 claws retracted into it. You push the spring loaded button on the end and the claws come out, let go and they retract back in hopefully grabbing whatever they have touched. I have a couple different sizes of them and I believe one is small enough to fit through a spark plug hole. If you get the piston pushed to the top of it's travel you may be able to get it out of there...
    Good luck man!
    Sep 2009
    Do you know what that flexy thing is called..could be step 2 after shop vac
    06 LSV
    Des Moines, IA
    Jun 2006
    That totally sucks dude.....I haope the shopvac idea works.....I would be very surprised if it does but I hope it works out for you.
    Aug 2010
    Orlando, FL
    If all else fails you'll need to put a wrench on the crank snout and rotate that cylinder to TDC manually. Should be easier to remove then.
    2005 Air Nautique SV211 Team Edition
    99 Moomba Boomerang- Sold
    Very sorry to hear this. Be patient. You'll get it out. At least you know where it is.
    Henderson, NV
    anybody remember the game "operation"?? I think jamie is about to get good at it
