Results 1 to 10 of 15
Thread: RED light under gear shifter???
10-13-2010, 11:44 PM #1Junior Member
- Aug 2010
- Chalmette, LA 10 miles South of New Orleans
- 4
I just noticed that the Red light under my gear shifter is ON. the light comes on once i start the boat and only goes OFF after i put the boat in gear and throttle up the around 1000 rpms. Under the red light is says do not run engine over 1200rpms if red light is on. But the light goes off at 1000-1200 rpms. i checked my oil in my V-drive and its good i also noticed though that after riding for a little while the v-drive does get a little hot, but that could be normal i dont know.
any help would be Great thanks
10-14-2010, 01:09 AM #2
I am pretty sure its normal.
I think it says "do not run engine if the light is on above 1200 rpm" or something along those lines.2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
10-14-2010, 03:11 AM #3
Hi there
It is normal for the red light to be turned on when you are in neutral, and as you wrote it turns off when you put the boat in gear.
The V-drive gets cooled with water and gets a little bit warm during operation.
Take care.
10-14-2010, 11:31 AM #4Senior Member
- Jun 2010
- Lake Houston
- 656
Absolutely normal. This light serves as your fluid level indicator for your v-drive. If the light stays on above 1200 rpm, your fluid level is low. But yes, it should be lit up BRIGHT RED when the boat is in neutral or just barely in gear.
2013 LSV
2005 LSV - SOLD
10-14-2010, 12:50 PM #5
Mine Never lights up! But then again, I have the DD.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
10-14-2010, 12:54 PM #6
watch that light if you surf. I noticed that the factory fill does not allow enough fluid if the boat is listing to one side. I had to add a little more to get it to go off when surfing..
10-14-2010, 12:55 PM #7Senior Member
- Oct 2007
- Panama City Florida
- 1,798
10-19-2010, 06:56 PM #8Junior Member
- Aug 2010
- 4
Thank you all very much i feel much better now.
thanks again
10-19-2010, 07:45 PM #9
it is the light for the pressure switch on the vdrive.......it will be on untill the oil pressure in the vdrive exceeds 2 psi....the v drive normally operates between 6 and 12 psi. i would suggest keeping the vdive at the full mark rather than the low mark.
09 21v LAUNCH
99 Outback LS. Sold
Doug
10-19-2010, 10:15 PM #10
2015 "NOT A MOOMBA"
