Results 1 to 10 of 15
    Aug 2010
    Chalmette, LA 10 miles South of New Orleans
    Default RED light under gear shifter???
    I just noticed that the Red light under my gear shifter is ON. the light comes on once i start the boat and only goes OFF after i put the boat in gear and throttle up the around 1000 rpms. Under the red light is says do not run engine over 1200rpms if red light is on. But the light goes off at 1000-1200 rpms. i checked my oil in my V-drive and its good i also noticed though that after riding for a little while the v-drive does get a little hot, but that could be normal i dont know.
    any help would be Great thanks
    Ottawa, Ontario
    I am pretty sure its normal.
    I think it says "do not run engine if the light is on above 1200 rpm" or something along those lines.
    Sep 2008
    Sweden
    Hi there
    It is normal for the red light to be turned on when you are in neutral, and as you wrote it turns off when you put the boat in gear.
    The V-drive gets cooled with water and gets a little bit warm during operation.
    Take care.
    Jun 2010
    Lake Houston
    Absolutely normal. This light serves as your fluid level indicator for your v-drive. If the light stays on above 1200 rpm, your fluid level is low. But yes, it should be lit up BRIGHT RED when the boat is in neutral or just barely in gear.
    2013 LSV
    2005 LSV - SOLD
    Aug 2009
    Montana
    Mine Never lights up! But then again, I have the DD.
    2015 "NOT A MOOMBA"
    Henderson, NV
    watch that light if you surf. I noticed that the factory fill does not allow enough fluid if the boat is listing to one side. I had to add a little more to get it to go off when surfing..
    Oct 2007
    Panama City Florida
    Thanks for clearing this issue up as I too have a DD and didn't know anything about a light under the throttle.
    Aug 2010
    Default Thank you all very much i feel much better now.
    thanks again
    it is the light for the pressure switch on the vdrive.......it will be on untill the oil pressure in the vdrive exceeds 2 psi....the v drive normally operates between 6 and 12 psi. i would suggest keeping the vdive at the full mark rather than the low mark.
    99 Outback LS. Sold
    Aug 2009
    Montana
    OK - Jinxed myself. I was in the process of winterizing (boat on trailer) and fogging the intake manifold. Got the arrestor off and pushed on the throttle flap to fog and that tripped my RED check engine light? What NOW? Did it trip a code on the ECM or something?
    2015 "NOT A MOOMBA"
