Results 1 to 9 of 9
Thread: How do you guys clean the hull.
10-09-2010, 11:34 AM #1
I let my boat sit in the water all season and only pick it up during autumn when itīs time to winterize the boat. During the season lots of crap sticks to the hull. I use oxalic acid to get the boat clean. (Oxalic acid is used in many boatcleaning products.) You can buy it from a paintshop and mix it with water, get it on the hull, wait a little bit and wash the dirt away, the dirt comes off really easily. It gets a lot cheaper than having to buy expensive boatcleaning products. Be sure you rinse the hull well and wax up the hull.
Take care
10-10-2010, 10:09 AM #2
SLIMY GRIMY.........mix it up with hot water in a small garden sprayer , spray it on ,watch it disappear. you can brush any hard stained areas......it even works 2 months after you bring your craft out of the water
http://www.youtube.com/watch?v=3snjD4Wz5dQ
and it works just like that WOW09 21v LAUNCH
99 Outback LS. Sold
Doug
10-10-2010, 10:22 AM #3Senior Member
- Jun 2010
- Lake Houston
- 656
Pretty amazing.
2013 LSV
2005 LSV - SOLD
10-10-2010, 12:00 PM #4
Wow.........docrs - have you used the stuff personally?
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
10-10-2010, 06:08 PM #5
Slimy Grimy
SLIMY GRIMY is very good product, I've been using it for the last three years on our XLV which is in the water from April to Oct. Bottom is white again with very little effort.
2007 Moomba XLV 340 ETX/CAT
10-10-2010, 11:52 PM #6
On-Off Hull cleaner works amozing, pretty caustic stuff though. I have nasty stains when I pull my boat at the end of the year as well. You brush this stuff on with a natural bristle brush and then rinse it off. Like I said, works great but it's nasty stuff/
10-11-2010, 12:49 AM #7Senior Member
- Jun 2007
- St. Albert, Alberta, Canada
- 164
50% water / 50% vinegar, then rinse. Applied with an adjustable flex neck car wash brush. Very little effort and time.
(Avoid Mastercraft Hull Cleaner. It does absolutely nothing. It falls short of delivering on it's intended purpose moreso than anything I could ever imagine. I bought it because it's what the Moomba dealer carried. Returned it. No more effective than straight water).'07 Outback V
Ski|Board|Surf|Skate
10-11-2010, 11:24 AM #809 21v LAUNCH
99 Outback LS. Sold
Doug
10-13-2010, 12:19 PM #9
I used to use sno-bol once a year and then wash with soap and wax.
