Results 1 to 10 of 25
10-06-2010, 01:13 PM #1
Engine wonīt suck antifreeze from a bucket
Hi there everybody.
I have the LSV -08 with the 325.
I was going to winterize my boat and thought I will follow cabīs excellent winterizing method and then fill up with antifreeze. I drained all the water from the engine and hoses. When I put everything togheter and tried to suck antifreeze the engine wouldnīt suck the antifreeze. I have a flush pro and the ball valve on the bottom of the boat was closed. I checked everything over and tried again with no luck. I then disconnected the flush pro and installed a hose in front of the V-drive and the other end in the bucket with antifreeze and started the engine, it looked like it was going to work, the engine started to suck up the antifreeze for maybe half a second and then nothing more. When i connect a gorden hose with waterpressure the engine gets water.
It is getting pretty cold during nights now and I would like to get the engine fixed.
Thanks in advance
Michael
10-06-2010, 01:17 PM #2Senior Member
- Apr 2010
- saskatchewan, canada
- 334
You must have a hose loose, that is allowing air in instead of creating suction. Check all your hose clamps to make sure they are tight. I just pull my intake hose apart right after the stainer and and hose clamped a rubber heater hose and funnel on. Started pouring in anitfreeze until no more would go in, then stared the boat and idled it up to 1500 rpm and kept pouring until it came out the exhaust.
Did you give the throttle a little shot and rev her up? Sometimes that is all that is needed and the suction will be created.
10-06-2010, 01:20 PM #3Senior Member
- Jun 2010
- Lake Houston
- 656
Have you checked the impeller? It might be in bad shape to the point where it wont suck on the bucket but water pressure will work.
2013 LSV
2005 LSV - SOLD
10-06-2010, 01:23 PM #4Senior Member
- Apr 2010
- 334
wouldn't his boat be over heating during the summer is the impeller was toast as it wouldn't suck water either?
10-06-2010, 01:26 PM #5Senior Member
- Jun 2010
- Lake Houston
- 656
Possibly, but the inlet actually has positive water pressure on it when the boat is submerged. And Im not sure where the raw water pump sits on his boat in relation to the water, but Im sure its pretty close to being submerged. May not be the problem, but Im just thinking out loud here.
2013 LSV
2005 LSV - SOLD
10-06-2010, 02:02 PM #6Senior Member
- Apr 2010
- 334
Fair enough, I just had that same problem a few years ago on my vintage malibu and it was a loose clamp.
10-06-2010, 03:08 PM #7Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
I always have my bucket of anti-freeze higher than the engine, so that once suction starts it will flow down with little effort.
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
10-06-2010, 03:20 PM #8
this is of absolutely no help to our friend in Sweden, but maxpower do you need to anti-freeze where you are in Florida?
10-06-2010, 04:00 PM #9Senior Member
- Jun 2010
- Lake Houston
- 656
Im at the same latitude and almost the same longitude as Maxpower and have personally seen a cracked block. Takes a few freak days, but it happens.
2013 LSV
2005 LSV - SOLD
10-06-2010, 06:37 PM #10Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Need? I don't know. However, it makes me feel better knowing that I won't have an issue in the spring. Also, anti-freeze has some capability IRT rust. Not here to start that debate, but I winterize with anti-freeze.
BTW, last winter we had several days below freezing and about 20 nights in a row below freezing for 10 hours+. My boat was in a storage unit, but I had no problems.1997 MasterCraft 205
2008 Moomba Outback
