Results 1 to 10 of 16
    May 2010
    Terre Haute, IN
    Default Keeping boat from freezing.
    Hey guys. I know there are guys on here that boat up till the temperture gets down pretty cold and all. I got a drysuit and stuff so I am starting to get where I can go longer and longer. But my question is when the temp at night is dropping down into the freezing range how are you guys keeping the boat motor from cracking? Or does everyone stop once that happens? Was just wondering. Right now the temp during the day has been aroudn the mid to upper 50s on some days. Not sure the temp at night. I want to keep boating but don't want to crack the block on my boat.
    her's a thread, peopl use work lights and blankets over the engine.
    Not sure its cold enough yet at night or during the day. I f you boat is on the lake , the lake water will keep it warm enough not to freeze until late nov, dec.
    water bottle trick is usually a good test.that will freez before your block
    https://forum.moomba.com/showthread....light=freezing
    Jun 2009
    Victoria BC Canada
    Quote Originally Posted by walb0244 View Post
    I have a small ceramic heater that I throw in the back locker and it keeps the boat nice and warm. It also stops the mildew from forming on my upholstery.
    2007 Outback V
    May 2010
    Quebec City, Quebec, Canada
    with a 100 watts in the bottom of engine compartment you can't be wrong
    ____________
    03 Mobius LSV
    For those of you who understand physics and the difference between heat and temperature I have wondered what filling ballast with hot water would do overnight on cold nights before winterizing. I would think the heat in the large quantities would warm the boat overnight. Thoughts anyone?
    May 2010
    Terre Haute, IN
    So a 60w light bulb puts off enough heat to keep the motor warm and not freezing up on me? My boat is kept out in the garage right now. Will try and move it to a shop soon so that the wind won't be as much of a factor. I figure wind chill might not help any.
    Nov 2009
    Murfreesboro, Tennessee
    After boating when you get home drain the water out of the block. Get you one of the shields from Lowes and put you a 100 watt bulb in it. Last winter I drained the water from the block and had 2 fixtures with 2 100 watt bulbs in them and clamped them to the engine mounts and closed the engine compartment, got down in the 20 in the shop for a while. I checked the temp in there everyday and it stayed above 35 in the engine compartment. Engine was fine all winter. So yours will be fine till you winterize your boat.
    It would have to be below 32 for a couple days to hurt anything. I wouldnt want to push it that close though.
    http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
    99 Moomba Outback with lots of work
    Interesting thought to use hot water. JV will need to check my math, but according to answers.com, a gallon of water weighs about 8.35 lbs, so a 750 lb sac would hold about 90 gallons. I think that would be a lot of H2O to heat and pay for if you're on county or city water in comparison to having a 100 watt bulb in the engine compartment.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    wasn't me on the hot water suggestion
    Jun 2010
    Lake Houston
    I mean, I would be a little scared introducing an ignition source in the engine compartment 100% of the time like that. Just sayin.
    2013 LSV
    2005 LSV - SOLD
