Results 11 to 19 of 19
Thread: Oil change gone bad
10-03-2010, 04:34 PM #11
04-06-2011, 05:43 PM #12
[QUOTE=badasshybrid;115400]Same as the one you have now.
http://www.summitracing.com/parts/TRD-1045/
Oh I am disappointed to see that the Trans dApt 1045, which is now in my mailbox, is smaller than that on my boat. They are identical except that the base is made for smaller filter. On the package they say for a filter # 1156.____________
03 Mobius LSV
04-06-2011, 06:01 PM #13
Trans Dapt 1056 is the right part...
____________
03 Mobius LSV
04-06-2011, 07:19 PM #14
discontinued... wow its getting better
____________
03 Mobius LSV
04-08-2011, 12:00 AM #15
How much smaller a filter? That may not be a bad thing, my newer vehicles seem to run much smaller filters. I hope Engine Nut will chime in for us.....
15 Mondo Surf Edition
02 LSV - Traded In
04-16-2011, 03:05 PM #16
half an inche
____________
03 Mobius LSV
04-16-2011, 03:56 PM #17Junior Member
- Apr 2009
- Okanagan
- 19
Call up any Indmar dealer in your area with your engine serial number and they should be able to order in.
04-19-2011, 01:20 PM #18
Call over to Indmar and ask for Larry. Give him your engine type/boat model and the max filter size that will fit that adapter. It will probably be fine. I know that my 2002 5.7 Indmar engine oil filter is much larger than my 5.3 Tahoe filter. I know that is a stretch of a comparison, but I would just check with Indmar. They are super helpful!!!
02 LSV - Traded In
04-19-2011, 11:44 PM #19
[QUOTE=MartinCaron;131670]Using the link to Summit Racing provided, I see the filter uses 3/4-16 in threads. If I remember right (from my days working in an auto repair shop) that is a common Ford/Chrysler filter, used on Ford V8 5.0 and 5.8 engines or a shorter version used on Chrysler V8 5.2 and 5.9 engines. It may be worth taking the adapter to an auto parts store and check into this. It may save you some headaches and get you back on the water. I can only remember Fram part numbers, PH8 or PH16. I would think that the filtering capacity would be the same between the two. You would be using a Ford filter instead of a Chevy filter. I hope that may help you out some in your situation.
