Results 1 to 6 of 6
    Sugar Land, TX
    Default Replacing dripless seal?
    I've searched and found plenty of how to's for replacing the old style, but has anyone replaced the newer dripless seals? I need to replace mine and was wondering if it was a job I could handle or if I should go ahead and let my dealer do it. I can handle mechanical projects, but without a little guidance I'll let the pros handle it.
    Current: 2010 LSV
    Previous: 2007 Outback
    Jul 2002
    London Ontario Canada
    Default Dripless Seal Replace
    seal $20-30 specify 1 1/8 or 1" oj props sells them and skidim
    OJ dripless is $125- 149 skidim maybe oj props
    There are clamps that hold the red rubber boot to the boat
    ,then clamps that the boot holds the seal housing to the shaft.
    These need to be tight. From the seal housing there is a blue hose
    that brings water from the exhaust mani to keep the seal water
    cooled/lubricated ,these clamps need to be tight. Then there is the
    Seal in the white housing. These 4 areas are sources of leaks, if its
    Your seal it can be replaced by undoing the 4 coupler bolts,
    mark your propshaft coupler and your v-drive couple so they are positioned the same when reassembling
    Loosen coupler nut retaining set screw,remove coupler nut and coupler
    off prop shaft ( I have posted this before on how to).
    (Loosen the nylock nut off the coupler, but not all the way off the the prop shaft threads, then insert a smaller nut or socket inside the nylock against the end of the propshaft so that it is protruding past the nylock and the coupler, then pull back against the drive shaft coupler and using 2 bolts tighten until propshaft coupler breaks free. (if driveshaft coupler has center opening you will need flat stock or lay another wrench across opening and use longer bolts to pull the 2 couplers together) tighten each nut about 1/8 of a turn at a time......this will act as a press to free the shaft coupler).
    Loosen clamps on
    seal housing and remove blue cooling hose. Slide housing off shaft.
    Remove blue seal cover, remove inner
    C-clamp that holds Seal inside seal housing and remove seal and replace
    With new one. Now take 1200 wetdry sandpaper and make sure prop
    shaft end edges and key way are smooth so won't cut new seal as it is slid
    back on shaft (there is also a protector
    that should come with your new seal that you can slide over the threaded end).
    Also smooth shaft in area of seal to make sure there are no pits on the shaft
    that may have caused failure. Oil shaft and slide on new seal, retaining clip and blue cover
    and reassemble. Now
    Check your alignment before bolting your couplers and adjust if
    necessary as this may be the cause of premature failure. Seals should
    Last about 400 hours before leaking. Hope its just a clamp but some
    Info fore the future
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Sugar Land, TX
    Thanks for the info - I need to replace both the seal and housing.....
    https://forum.moomba.com/showthread.php?t=12870
    Current: 2010 LSV
    Jul 2002
    ah yes , I remember now, you should install a strainer as well
    mine had to be replaced as it was leaking from day one, long story and i will tell it soon but now they are replacing the v-drive as it is leaking oil from multiple places. I let the dealer do it as it was under warranty but wouldn't hesitate to do it now......
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Aug 2009
    Montana
    how do you know when you need to replace it? Water in the bilge area?
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Jul 2002
    yes , you will have water in the bilge........it may or may not drip when sitting in the water, but will drip when you are under way....at least thats what mine did. TL7's prob overheated due to a lack of water lubrication and fried the seal carrier because of weeds possibly plugging the supply line. I would suggest a pre v-drive water strainer
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
