    Saugus, Mass
    Default trailer hub spraying oil
    I have the oil well hubs on my trailer and noticed a spray pattern last time I trailered the boat. Does anyone know how these seal. I drained whatever oil was left in the hub and pulled it off, but I'm still not sure what makes the seal. If anyone has any experience with these let me know. Thanks.
    Jun 2009
    Newberg, Oregon
    Since you lost your seal, I would change your bearings as well. The trailer bearings are made by Timken.
    Here is what is said on the Trailer Buddy manual for the Gold Series Oil Bath Hubs:
    http://www.ufpnet.com/Portals/0/trai...ygoldmaint.pdf
    REPLACING SEALS
    The hub or rotor must be removed from the axle and the seal forced out. It is
    impossible to remove the seal without damaging it. So, when you remove it,
    plan on replacing it. Because seals are a high quality design not widely
    available, you will have to obtain a replacement from the dealer, a bearing
    supply company, the trailer manufacturer or Unique Functional Products. Seals
    installed at the factory may have a hypalon coating on the outside diameter. If
    you replace seals without hypalon apply a thin film of Permatex High-Temp
    RTV Silicone Gasket Maker on the seal outside diameter and hub bore prior to
    installation.
    Seals currently in use are:
    Axle Load Seal Outer & Inner Inner
    Capacity Diameter Bearing Cone
    1500#-2500# 1.98” x 1.38” L44649
    2900#-4200# 2.33” x 1.68” or L68149
    2.56” x 1.68” L68149
    5200# (6 Bolt) 3.38” x 2.13” 25580
    3.26” x 2.13”
    5200# (8 Bolt) 3.38” x 2.13” 25580
    SEAL CONVERSION INFORMATION
    Replacement Part Numbers
    Seal Trailer
    Description Buddy NOK CR National
    198-138-SP1-1 07026 AB1990EO 13557 482163N
    233-168-SP2-1 07027 AD2527EO 16657 473317
    256-168-SP2-1 07028 AD2528EO ––––– ––––––
    326-213-SP2-1 07029 AD7131EO ––––– ––––––
    338-213-SP2-1 07040 AD8717EO 21352 ––––––
    Nate
    Jun 2009
    Newberg, Oregon
    For what it costs for the bearings and seals I would just change it all. Especially if you do not know why the seal failed for sure. And if you do not know how long ago the seal had actually failed you could have water damage, among other types of damage, to your bearings.
    If you have the Gold Series hubs like i have on my trailer, here is the link for the bearing and seal kit. You just need to figure out your ID of the bearings to get the correct seals for them.
    http://www.pacifictrailers.com/Trail...68149/L44649-/
    Flat did you change your bearings are well? Most likely you sucked a lot of moisture into your hubs and probably have/had water damage on your bearings.
    Nate
    Saugus, Mass
    Does anyone know where to find the ID of the bearings?
    Jun 2009
    Newberg, Oregon
    You will need to measure the ID and OD of your seals to determine which size to get. Your ID should be 1.68 and your OD will be either 2.33 or 2.56.
    I would go take alook at my trailer, but I do not have it right now.
    Nate
