Results 11 to 16 of 16
09-22-2010, 11:38 AM #112008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
09-22-2010, 11:46 AM #12
I followed that thread as it was going on.
For purposes of my questions:
1.) Platform brackets attached to Platform - 1 hole each side
2.) Platform bracket hanger attached to the transom - 2 holes each side
3.) Platform bracket slides into platform bracket hangers and secured via pins
The one question I had about the solution - Did you weld up and re-drill just the holes on the Platform brackets or did you take the hangers off the boat too and weld/re-drill those?
Either way did you have to re-finish the metal with paint or what did you do there?
Thanx
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
09-22-2010, 12:11 PM #13Senior Member
- Sep 2005
- Claytor Lake, VA
- 599
viking
Welded up the platform brackets only and painted with semi-gloss black. Original holes were 1/4" so 5/16" made sure all lined up.
deafgoose
Post contained a link to SS lock pins with an explination why they were 5/16 instead of 1/4. Searched platform+pins.
09-30-2010, 07:35 AM #14
09-30-2010, 07:42 PM #15
deafgoose did you try Ottawa fastener supply on Robertson RD
that is ware i bye all my stainless screws,nuts and bolts.2012 Mobius LSV
05 Outback LS SOLD
09-30-2010, 10:10 PM #162008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
