Results 1 to 10 of 14
Thread: VDrive Fluid
    Jun 2010
    Lake Houston
    Default VDrive Fluid
    What fluid are you putting in your VDrive. The only "SAE 30" that I could find was Wal-Mart brand. Are any of you running synthetic? Synthetic or not, where are you getting your oil? Cheers.
    2013 LSV
    2005 LSV - SOLD
    Henderson, NV
    head to your local auto parts store. there are lots of choices in 30wt oil.
    Sep 2009
    How often do you change this and is it basically just an oil change from the v drive? Where's the drain? (I imagine it's in the manual but don't have it here at work).
    Jun 2010
    Lake Houston
    I change mine every season. The manual has you change it every X hours. There is no drain. You have to suck it out. You can take the pan (access cover plate thingy) off the bottom to drain it, but that just makes a huge mess. Its designed to be sucked out.
    2013 LSV
    2005 LSV - SOLD
    Sep 2009
    Thanks I'll try to find the access on the v drive or look in the manual for it.
    Maybe this is a silly question but how come this isn't a part of the winterization thread?
    Des Moines, IA
    Use any non detergent 30 wt oil per the manual. There is a drain and screen that should be cleaned as well on the lower rear of the unit.
    Feb 2006
    Birmingham
    Either Auto Zone or Advanced Auto sells Valvoline SAE30 in our area, I can not remember which one it is. I always buy 2-3 quarts and change it every year.
    15 Mondo Surf Edition
    02 LSV - Traded In
    Des Moines, IA
    Quote Originally Posted by pmoomba View Post
    Though many people perform the v-drive service at the same time, it's not really part of winterization. It's just scheduled maintenance.
    Jul 2002
    London Ontario Canada
    there is actually a drain plug and a screen that should be cleaned, i believe/know its all in the schematics.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Sep 2005
    Claytor Lake, VA
    I removed the bottom cover from my v-drive last winter to repair a small leak and was curious to see what the screen looked like after 5 seasons. Screen was clean and just a small amount of build-up in the corners of the cover. It's also a good idea to pull the top and clean out debris from the cooling water. Make your own gaskets with RTV.
