Results 11 to 14 of 14
09-16-2010, 12:43 PM #11
09-16-2010, 04:58 PM #12
09-16-2010, 06:40 PM #13
You would have a total of four conductors running up the tower, L +&- plus R +&-. The two left speakers would be wired in parallel for a 2-ohm load and the same with the right. The JL amplifier is comfortable with a 2-ohm load.
Earmark Marine
09-16-2010, 08:15 PM #14
Trebor,
As David says, you run one pair of speaker wires (+ and -) to each side of the tower, connect the speaker wires to one speaker, then connect the first speaker to the second by wiring the positives together and wiring the negatives together. Do the same for the other side. The amp will see a 2 ohm load per channel. The JL amp puts out 180W continuous per channel at 2 ohms and since you are pushing two speakers with each channel, each speaker would get 1/2 of that, or 90W which is plenty for the db651's.
Hope that helps.
AlAl
