Results 1 to 10 of 11
Thread: Vdrive pull
09-15-2010, 07:32 PM #1
Vdrive pull
anyone ever pulled their vdrive before? how many bolts holding it to the tranny?
09 21v LAUNCH
99 Outback LS. Sold
Doug
09-15-2010, 08:02 PM #2
why ya need to pull the v-drive
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
09-15-2010, 08:29 PM #3
its leaking oil out the shaft.......wish it wasn't but 99.9% sure it is, spent about an hour on the lake confirming my suspicions......found a pic, looks like its only about 8 bolts and the coupler
09 21v LAUNCH
99 Outback LS. Sold
Doug
09-15-2010, 08:42 PM #4Senior Member
- Jun 2010
- Lake Houston
- 656
Yeah man mine leaks a bit too. I will soon be doing this. You should take a lot of pictures. Cheers.
2013 LSV
2005 LSV - SOLD
09-15-2010, 09:16 PM #5
where is yours leaking?
09 21v LAUNCH
99 Outback LS. Sold
Doug
09-16-2010, 09:19 AM #6Senior Member
- Jun 2010
- Lake Houston
- 656
Im not sure yet. I will look this weekend. I have always had a "sheen" on my bilge water and could never figure out where it was coming from. Well this last time I took the boat out the little light stayed on, after I got into the throttle so I have been periodically checking the level. It was "good" when I got the boat and after 20 engine hours it is a little low. So its a leak, but a small one. Ill take a gander though when I fill up the reservoir this next time out. Cheers.
2013 LSV
2005 LSV - SOLD
09-16-2010, 04:11 PM #7
the most common place is the sensor, wrap a paper towel around it to comfirm, then a lower fitting i believe there are 4, then the lower cover plate..make sure bolts are tight, then the shaft.....i can get oil consitently from where the shaft exits......you can also place a paper towel under your v drive and see where the oil drips on it.......
09 21v LAUNCH
99 Outback LS. Sold
Doug
09-17-2010, 07:05 AM #8
guys my Vdrive is on the floor if you need any pics let me know.
06 XLV
09-17-2010, 07:48 AM #9Senior Member
- Jun 2010
- Lake Houston
- 656
Taking the boat out today, so Ill know more this afternoon.
2013 LSV
2005 LSV - SOLD
09-17-2010, 11:20 AM #10
davinci, i'm curious as to how much the vdrive weighs, and where exactly it unbolts from the transmission and how it melds with the transmission...ie splined shaft,is there a gasket between the vdive and tranny?.......my boat is 3 hours away right now. Any photos would be greatly appreciated
09 21v LAUNCH
99 Outback LS. Sold
Doug
