Results 1 to 10 of 14
    Sep 2010
    Wichita, KS
    Default Window Mount Mirror
    has anyone looked at installing the Malibu mirror mount on their Moomba? Had bad luck with last tower mount mirror and have been in both a Malibu and an Axis which had the c shape mount that mounts the to door window.
    Am not sure if the window setup is the same or not .
    Ottawa, Ontario
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
    Sep 2010
    Wichita, KS
    Default Not the same
    No it is not. The one that the Malibus have is a 8" C or U shape tube that screw to windshield rail and then the mirror mounts to it.
    Henderson, NV
    if you want one like the thread above, pm me, as I have one that I don't use and it works great..
    Feb 2009
    Quote Originally Posted by gonracn View Post
    I think I have the one that you are looking for and I don't use it. Give me some time to snap a picture and show you what I have.
    Des Moines, IA
    What kind of bad luck did you have with a tower mirror?
    Feb 2009
    Quote Originally Posted by Hoopskier View Post
    Here is what I have, let me know if your interested.
    Sep 2010
    Wichita, KS
    It would not hold its position no matte how tight or often you tightened the mount. The mirror would also not hold positio on on the arm.
    Dec 2006
    Tigard, Oregon
    My monster mirror arm and mirror NEVER move. The clamp has not moved a millimeter since I installed it 4 years ago and I remove the arm after each use (has a quick release). The mirror also stays put no matter what.
    It's not the fanciest arm out there but it's solid and has a quick release, which I really like.
    Al
    Al
    Des Moines, IA
    Al
    Agree completely
