Results 1 to 10 of 20
Thread: Is this normal
09-09-2010, 09:49 PM #1
Is this normal
Wanted to start working on the engine , so I decided to begin replacing the impeller. I removed the cover and discovered that the impeller is squished on the right side ....is this normal ??
06 XLV
09-09-2010, 09:51 PM #2
They need to be offset so they create vacuum. Proabbly OK unless the center appears broken or loose.
09-09-2010, 09:53 PM #3
yes that is totally normal, however the surprising to see some of the arms pointing in the opposite direction, I'm taking it you are replacing it...a pair of large needlenose visegrips some silicone spray lube and bingo its out, rotate the new one in a clockwise rotation as thats the way it spins.......I wouldn't put the new one in untill your ready to use it no sense in compressing the arms when not necessary...
09 21v LAUNCH
99 Outback LS. Sold
Doug
09-09-2010, 09:55 PM #4
Great ..thanks guys I will attack it tommorrow , hope it comes out easy !!
06 XLV
09-12-2010, 01:32 PM #5Sled491 Guest
that is normal, and looks fine, just my 2 cents
09-12-2010, 08:10 PM #6
Does the new impeller come with a gasket as well ? The reason i'm asking is because I was reading through cab's winterization , some of you remove the impeller for the winter but what about the gasket, since it's no good anymore once removed do they sell them apart ?
06 XLV
09-12-2010, 08:23 PM #7Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
Whenever I've bought a new impeller they always came with a new gasket. Give skidim.com a call.
2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
09-12-2010, 09:08 PM #8
09-13-2010, 08:28 AM #9Sled491 Guest
They come with gasket and mine came with a small amount of lubricant
09-13-2010, 12:19 PM #10
As per the posts before this, yes most come with gaskets. However my last impeller came from the dealer and they just gave me the impeller (no gasket or lubricant). When I changed I was carefull and used the old gasket and no problem at all this season. Visually inspect it when you have the cover off and it might be just fine. If there is a new one in the kit though - why not use it
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
