Results 1 to 6 of 6
Thread: EQ install?
09-08-2010, 11:06 AM #1
EQ install?
Can some of you who have installed an equilizer let me know how you mounted it under your dash. I don't have much fiberglass under there. I spent all of last nite trying to figure out where I should mount it. If anyone has pics of the underside or of a mounting board that they have installed that would help a ton...
09-08-2010, 11:25 AM #2Senior Member
- Jun 2010
- Lake Houston
- 656
Which EQ did you get?
2013 LSV
2005 LSV - SOLD
09-08-2010, 11:48 AM #3
Eric which boat do you have.
I bought some L brackets and added them to the bolts for the steering column, directly under the wheel. I think the bolts are 1/4 or 3/8. then screwed a piece of abs plastic to the bottom of the L brackets then screwed in my eq to the abs plastic.
here is a good link by doc.
top of second page shows docs mount, i used the steering bolts to the right do to the lack of platsic. further down is a finished mount pic of mine on page 3.
https://forum.moomba.com/showthread....t=mount&page=2Last edited by jmvotto; 09-08-2010 at 11:53 AM.
09-08-2010, 11:49 AM #4
Soundstream...
It was cheap I was just looking for something to be able to fine tune without having to go under the passenger side and mess with the amps. It is a seven band adjust with sub control for $49 shipped. I will let everyone know how it works when I get it done.
09-08-2010, 11:51 AM #5
Good idea, I just want to make sure its solid.
09-08-2010, 11:51 AM #6
I have an 06' Mobius LSV....
