    Ottawa, Ontario
    Default Center ballast problem
    I can fill and empty the center ballast but when I drive the boat it fills on its own. Also... when I fill the left and right ballast without filling the center, some water gets into the center while those two are filling.
    I checked those small black levers on the sprinkler pumps and they are all up so that can't be the issue.
    What else could it be?
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
    The levers may not work on the center solenoid , Or you may have to take it aprt and see if any debris is stuck in there keeping it open. i think eight or ten screws and it comes apart.
    Ottawa, Ontario
    That makes sense. I will check that out today. THANKS!
    Mar 2008
    Vancouver WA
    I had some of the same symptoms you had, and found no debris but what I did find was alge growing in there. I cleaned them out with some bleach water and they work good as new.
    PWI as usual...
