Results 1 to 7 of 7
Thread: Tightening a rudder?
08-26-2010, 02:51 PM #1Junior Member
- Aug 2010
- 3
A friend of mine has a 2007 Outback V and he asked me if I would be able to help him tighten the rudder, he says that there is play in it that was not there before. I have little experience with boats so im trying to find out if this is something that is possible and if what all is needed?
08-26-2010, 03:07 PM #2
It really depends. If the rudder port (a kind of bushing) is worn, then there is no tightening. It will take replacing parts. However, if there is play at the end of the steering cable you may be able to do something about it. It will require a close inspection with one of you moving the wheel and/or the rudder and the other watching what happens.
08-26-2010, 03:33 PM #3Junior Member
- Aug 2010
- 3
From what I can tell its not a linkage issue, there is movement front to back and left to right. It doesnt seem excessive to me but he assures me that there did not used to be any play in it and that he can feel some vabration through the steering wheel
08-26-2010, 04:58 PM #4Senior Member
- Oct 2007
- Panama City Florida
- 1,798
The rudder passes throught a bronze bushing called a rudder port. Seems like yours may be worn. You also have to believe that the rudder is also worn. This is best handled by the dealer unless you can live with the vibration which could be from something else like dinged prop. Check out the prices, and yes I have had to do this with an older ski boat.
http://www.go2marine.com/product.do?no=86215FLast edited by zegm; 08-26-2010 at 05:00 PM.
08-26-2010, 04:59 PM #5Senior Member
- Jun 2010
- Lake Houston
- 656
2007 and the bushing is already worn? How many hours?
2013 LSV
2005 LSV - SOLD
08-26-2010, 06:38 PM #6Junior Member
- Aug 2010
- 3
Im not sure on the hours, I dont think its a lot, I know all he really does is surf behind it, what are the chances of this being the issue? what else should we look for?
08-26-2010, 10:00 PM #7Senior Member
- Oct 2007
- 1,798
My rudder would swing way over to one side and back to the other BUT I didn't have vibration in the steering wheel. With something being a little loose like this (rudder)it is NOT a good path for vibration anyway. And it took 20+ years for mine to wear out. I would be looking for dings or small dents in the prop.
