Results 1 to 10 of 15
    Jun 2010
    Lake Houston
    Default Trailer Shuddering
    So I tried doing a search on this and theres a ton of info that pops up when you search "trailer brakes", but I didnt see anyone thats having my specific problem. Yesterday when I was towing the boat out to the water, everytime Id hit the brakes like coming up to a light or to make a turn the trailer would shake violently. Anyone have this problem or know what the deal is. I dont even know what kind of brake system I have on the trailer. Its a boatmate, and Im sure it has surge brakes on it because the tongue will slide in and out at this pin that goes through it. Thanks wayyyy in advance. This forum has been a life saver.
    2013 LSV
    2005 LSV - SOLD
    Jun 2009
    Newberg, Oregon
    I had this problem once. In my truck the fuse that controls the trailer brakes was blown. The fuse that controls the lights was still ok. I would go check your fuses first.
    Nate
    Jun 2010
    Lake Houston
    I dont have a brake controller on this truck unless its built in and I dont know about it. Usually theres a little box or whatever right?
    2013 LSV
    2005 LSV - SOLD
    Jun 2009
    Newberg, Oregon
    I don't have a trailer brake controller either. But your trailer brakes are still controlled by the truck. When you push your brakes the trailer brakes engage. When the fuse is blown your trailer brakes will no longer engage when you engage your truck brakes. At least with Ford there is 2 inline fuses for the trailer hitch reciever. One that controls the lights on the trailer, and one that controls the brakes on the trailer. I would look in the manual for your truck and see which fuses control the trailer hitch reciever and see which one is blown.
    The violent shaking is causes be the tongue on your trailer is sliding in and manually engaging the trailer brakes.
    Nate
    OK little confusion here guys.
    1 Boat Mate uses hydraulic surge / pressure brakes with 1 electrical component.
    If you have electric brakes you have to have a brake controller like what i have in my F350 and the trailer has to have an on board battery to power the breaks in case the connection is lost to your truck.
    Boat Mate brakes work on this system = Electrical connect is a valve that only stops the trailer from rolling back wards. Its hard to explain but its basically an electrical valve that apply the brakes only when you try to reverse it. Thats the only electrical part about the brakes.
    The trailer brakes work hydraulically by the weight of the trailer. When you press the truck brakes, the forward force of the trailer will push on the truck, this in turns causes the sliding section of the trailer tongue to compress, applying an equal amount of force to the brakes.
    Think of it as you press the truck brake pedal, the tongue is the Brake Peddle for your boat trailer.
    This same effect happens when you go down steep hills, the trailer will try to force your truck forward and apply the trailer brakes automatically to slow the trailer down. Even if you don't press the truck brakes the trailer brakes will be applied. Natural gravity does this for you.
    This is exactly why you NEVER NEVER did i mention NEVER drop your trailer in the water as soon as you get to a ramp if you were traveling down hill for a good bit. The brakes are smoking hot and you will at best warp the rotors, at worst you can crack them and or blow out you brake caliper seals and or worse yet sealed axle bearing seals.
    I take some water and splash it on my brakes, if it sizzles then i wait longer till they don't sizzle.
    I was at Lake Billy Chinook all weekend and its a narly down hill grade, i could smell my brakes they got so hot and we waiting 30 minutes at the launch prep area to cool off. Sucks but doesn't suck as bad as breaking my trailer brakes.
    Now to the original problem, first check the fluid level on the trailer, back plastic can on your tongue. Should be full, uses standard break fluid. Full? Then shuddering is most likly warped brake rotors and they need to be resurfaced or replaced. This is the same thing as when you press your brakes in the car and feel vibration in the steering wheel.
    [COLOR="#696969"]
    Oct 2007
    Panama City Florida
    I agree --- warped rotors!!!
    And boats trailers don't ever use electric brakes, something about water and electricity. Now horses!!!
    Jun 2010
    Lake Houston
    Wow great information! Thanks for typing all that out, I definately did not gather that from the searching that I did. This JUST started happening and I believe it to be intermittent. Ill check the brake fluid when I get home and report back! Theres SOOOOOOOO much maintenance and different things to check with these boats its ridiculous. What a maintenance nightmare, but you gotta pay to play right?
    2013 LSV
    2005 LSV - SOLD
    Oct 2007
    Panama City Florida
    Quote Originally Posted by lewisb13 View Post
    Well if you are like me and you have too many toys that you can't afford to get them maintained / repaired............well I have to get dirty to play and do it myself! But it turns out to be an education and then I know what I do need to do and what I don't need to do. Then when I do take them in for maintenance I know what really needs to be done and what they don't need to charge me for! The last time I took something in to have it mainained it cost me the engine in my boat! Luckily SC took care of that and I change my own oil now.
    Thats a fact, and most of us that own these boats do all the maintenance in the off season, but you still gotta do some in the boat season, you have to pay to play or learn to do it yourself to afford to play <myself included>
    [COLOR="#696969"]
    Jun 2010
    Lake Houston
    Quote Originally Posted by zegm View Post
    Im a mechanical engineer so I have a fundamental problem with letting anyone work on my stuff besides me. Id change anything in this boat with my bare hands if I had to. But man, between the 4 dirtbikes, my crotch rocket, my tow vehicle, and my turbo daily driver, and this boat I barely ever have any free time lol.
    2013 LSV
    2005 LSV - SOLD
