Results 1 to 7 of 7
    Sep 2009
    Copperas Cove, TX
    Default Whoa!!! Fast service dept.
    Dropped off my boat Tuesday morning for for 50hr service and to have bilge cleaned (found out the secondary oil pickup was leaking slightly). Just got the call it was ready. Wow!!! A day and half only when they said 7-10 days.
    Aug 2009
    Montana
    Did you get ur boat back with footprints all over again Or is this a different dealer? Or did they get "learned"? ha ha
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Sep 2009
    Copperas Cove, TX
    We shall see tomorrow morning when I pick her up (dealer is hour and a half away)
    Jun 2009
    port washington, ohio
    Quote Originally Posted by you da man View Post
    50 hour service? i thought you do 20 hour then on every hundred?
    08 lsv all red- dual battery system, kicker 700.5 and 450.2 amp, 10" kicker sub, wetsounds eq, polk db651 cabin speakers, exile xm7 tower speakers, ss thru hull fittings, seadek pad, evolutions cover
    https://forum.moomba.com/showthread.php?t=10664
    Jul 2002
    London Ontario Canada
    I believe Indmar recommends q50h oil n flter change
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Sep 2009
    Copperas Cove, TX
    Quote Originally Posted by gus 08 mobius lsv View Post
    Better check your manuel. Every 50hrs oil/filter and fuel filter in addition to the other fluid level, hoses, lines, and strainer checks
    Jun 2009
    ok i knew the oil change had to be done and done that on 48 hours but i thought you meant it was extensive like the 100 hour check.
