Results 1 to 10 of 16
    Nov 2009
    Gatineau, Quebec
    Default engine won't pass 1200 rpm (help)
    Hi i need some help im at the cottage on vacation the problem is when i'm accelerating it will stop at 1200 rpm even when i push full throtle the engine does not mis or run bad in any way i must bring it back to nutral and accelerate three times or more before the boat will run good turning the key off and restarting it will run good
    325 tbi 262 hours i suspect tps but not sure closest dealer is 4 hours
    2012 Mobius LSV
    05 Outback LS SOLD
    Dec 2006
    Tigard, Oregon
    Quote Originally Posted by papou View Post
    Do u have perfect pass?
    Al
    Nov 2009
    Gatineau, Quebec
    yes i have perfect pass
    2012 Mobius LSV
    05 Outback LS SOLD
    Jun 2006
    If the problem is only while under load and it revs fine in neutral I would start with the fuel filter which should be changed every 100 hours.
    Jun 2009
    Victoria BC Canada
    Is it turned on? (Giggle)
    2007 Outback V
    Jun 2010
    Lake Houston
    My engine was doing this when the impeller went. The boat was going into "limp" mode. Check and make sure your boat isnt overheating.
    2013 LSV
    2005 LSV - SOLD
    Nov 2009
    Gatineau, Quebec
    Quote Originally Posted by Canuckle Head View Post
    no it even does it when its disconected fuel filter,water separator.cap and rotor wires and plugs all new. I checked the impeller and it good.
    phil
    2012 Mobius LSV
    05 Outback LS SOLD
    Jun 2010
    Lake Houston
    I mean lets talk basics here. Your engine starts so you know that timing, fuel, and spark are there, but when you try to increase the fuel delivery (more throttle) the engine wont do it. Cap and rotor? Mine is distributorless ignition also. Sounds like you might be having some vapor lock issues possibly. You using the BLUE stabil? Just thinking out loud here.
    2013 LSV
    2005 LSV - SOLD
    Nov 2009
    Gatineau, Quebec
    Quote Originally Posted by lewisb13 View Post
    i don't think its vapor lock if i shut off ang restart it will run good the boat will do it cold to.
    phil
    2012 Mobius LSV
    05 Outback LS SOLD
    Jun 2010
    Lake Houston
    Any way to verify fuel pump pressure?
    2013 LSV
    2005 LSV - SOLD
