Results 1 to 6 of 6
Thread: Exhaust puncture
08-18-2010, 12:02 PM #1Junior Member
- Aug 2010
- 1
Exhaust puncture
I have a hole in the exhaust. It's about the size of the tip of a pinky finger. The whole is flowing a constant stream of water into the engine compartment. bilge works fine so it is mitigating most of the water intake. What material can I use to patch the whole?
08-18-2010, 12:03 PM #2Senior Member
- Jun 2010
- Lake Houston
- 656
High temp quick steel? High temp JB Weld? MIG welder?
2013 LSV
2005 LSV - SOLD
08-18-2010, 03:02 PM #3
Is the hole in the manifold,hose,muffler,thru hull?
04 LSV
08-18-2010, 05:37 PM #4
Are you sure it's not the muffler drain? If so you just need to find the screw in the bilge area. Even if it's not the drain I'd be tempted to "patch it" in the same way the drain hole is plugged - self tapping screw. Any other patch you run a good chance of failure due to constant water/heat exposure.
08-18-2010, 05:39 PM #5
08-19-2010, 12:29 AM #6
Ya - and where is the hole? manifold, exhaust tube, ect.... That would make a difference.
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
