Results 1 to 7 of 7
Thread: Board Size?
08-16-2010, 08:45 AM #1Senior Member
- Jun 2010
- Lake Houston
- 656
Board Size?
Im just curious as to what size board I should be using. I am 5'11 and weigh 160 lbs. I can do inverted tricks here and there and would like to get much better. I am currently riding a 140 State with State bindings, but I feel like Im being held back by the board, but not sure...
2013 LSV
2005 LSV - SOLD
08-16-2010, 10:12 AM #2
You should be getting a 135-139
http://www.evogear.com/how-to-choose...ize-chart.aspx2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
08-16-2010, 10:17 AM #3Senior Member
- Jun 2010
- Lake Houston
- 656
08-16-2010, 11:47 AM #4
I'm 6'00" and 160. I ride a 139 Ronix. You'll find it's all preference. You'll even see some lightweights riding 140+ length boards and some of the best female riders are doing the 140 boards.
08-19-2010, 11:21 AM #5
i'm 5'8" and riding a 137... my first board was a 143 and since then my last 2 boards have been 137's and i find that for me it's the right size... it's just like when your buying a boat.... get in (or in this case "on") as many diff. lengths of boards before you buy...
One of my buddies is the same height as me but he weighs 245 and he rides a 137 as well... i'd of thought he'd need more board but that's what he likes...
Geoff2014 Mondo with da flow!!! Exile towers, stock everything else.... for now!
08-19-2010, 05:13 PM #6Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Board size isn't really the issue as many different sizes "fit" many different weights. You should determine what you like and don't like as far as charactertics of a board. 3 stage or continuous rocker. 0, single, or multiple rails, intergrated or removable fins, tail shapes, and overall wideth. Also, don't think that one board maker makes that "best" board, you may find that you like Ronix, LF, HL, Obrien, etc, better than your current board.
Once you determine what you like in a board, then you can search for the"right" board. I like 3 stage rocker, multiple rails, traditional tail shape, and single removable fins. It works for the way I like to ride (or my style, if I have any).1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
08-20-2010, 01:53 PM #7Junior Member
- Jul 2010
- MI
- 28
There is no magic formula for the perfect board size... your best bet is to find a shop that will allow you to demo the boards. Generally there are 3-4 board sizes per model... you would probably fit somewhere right in the middle (136-140cm) if you go too small though, it will give you the sense that you are being pulled too slow because the board will be riding too deeper in the water, and feel slow and heavy.
'01 Mobius
