Results 1 to 8 of 8
Thread: Starter
    Jan 2010
    cumming, ga
    Default Starter
    The engine starter fuse (20 amp) keeps blowing. I've checked my battery and stater connections and everything seems fine. Any suggestions?
    Pain is weakness leaving the body!
    2009 Outback V
    Jul 2013
    I got the same problem. Anyone?
    Jul 2013
    Holiday weekend and I got boat problems!
    Feb 2005
    Ottawa, Ontario, Canada
    I know how you feel. My starter began failing on the last long weekend (1st Monday in August here in Ontario). It had different symptoms though. It wouldn't disengage fast enough. I wish I could help you.
    Pensacola, FL
    Check your connections at the battery and the grounding wire that attaches to the block.
    Inspect the wiring going to the starter for chaffing.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Aug 2009
    Richfield, WI
    Yep...starter propabaly going bad and drawing to much current...my little ballast emptying pump was doing that (blowing fuses) until it finally crapped out.
    I would do as recommended above just to be sure...check all the battery connections..
    Default Re: Starter
    The fuse on the dash? Replace the fuel pump it's drawing to much power and tripping the fuse... the starter uses a relay and the starter should get it's power from the battery directly, no fuses..
    2006 Moomba Mobius LSV
